AWD 964/911 Bus
john&hannah
Door Check fitting
Post by john&hannah »
Got the old door check mount and spring into the new door frame and trimmed the frame aperture to fit (can't be that hard to cut this hole during manufacture, just a thought KlassicFab!)
ImageDoor check by Duke of Boots1966, on Flickr
All done
Re: AWD 964/911 Bus
Earlier buses did not have door checkers. Klassicfab panels you have are for earlier models. Hence no fiitings/ apertures etc in your A posts and doors. Others have retro fitted checkers to early buses as you have.
john&hannah
Re: AWD 964/911 Bus
Indeed they do BUT KlassicFab market their doors like this -
Screen Shot 2020-06-18 at 13.17.07.png (115.55 KiB) Viewed 1158 times
.....and I ordered the one on the right 63/67 so was rather expecting a door check hole.
Never mind, least of my build worries.
Re: AWD 964/911 Bus
I have the personal mail of the owner if you want to moan. But he is really FIERY.. great sport.
Looks like one hand early one hand late..
john&hannah
Re: AWD 964/911 Bus
Both handed the same I just put an early left next to a late right as that’s how they were on the website and an easy screen grab. The later rh and lh both come without the check holes and the pressing flanges are not the same either, will post photos later, so if you are a perfectionist then you may be disappointed.
john&hannah
Re: AWD 964/911 Bus
Some dash work today -
ImageDash it by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Some more progress including my new invention the Split Screen Airfix kit
ImageIf Airfix did splittys by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Chassis back from the spray shop and the torques has been lengthened by 140mm and fits like a glove.
ImageChassis and Suspension by Duke of Boots1966, on Flickr
Front trans in with extended torque tube -
some great fabrication by the Somerset boys in Henstridge
john&hannah
Re: AWD 964/911 Bus
New Shiny stuff for the rear suspension -
ImageShiny stuff by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Cutting the bench seat extension (not sure thats the right description) of the old tool chest and onto the new one. I ordered a new tool chest panel and it did not come with this extension but i now know heritage parts centre do one - https://www.heritagepartscentre.com/uk/ ... l-box.html
ImageBench seat extension by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Backwards and forwards controls will go about here i think - version 1
ImageGear shift mount mk1 by Duke of Boots1966, on Flickr
Will use the gear change from the Porsche 964 and extend the gear shift rod. if that fails then its over to this system and more £££££££
john&hannah
Re: AWD 964/911 Bus
Shiny sub frame back from powder coating -
ImageShiny stuff II by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
The gear change set up is proving challenging and have resorted to a 1904 period wooden set up -
ImageCirca 1904 wooden gear shift option by Duke of Boots1966, on Flickr
Front mount on back of front panel
Looking backwards under the tool chest as the gear change rod just misses the front drive shaft
john&hannah
Re: AWD 964/911 Bus
New wheel bearing pushed into the newly powder coated 996 hubs
ImageBearing up to the pressure by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Safety first - seat belt mounts fitted to b pillar -
ImageSeat belt anchor by Duke of Boots1966, on Flickr
