kühlspeed Ram Air Scoops from £96+p&p
dsbus
Post by dsbus »
Unlike others made in the USA back in the day, this option is not permanent, "no holes to drill in bodywork"
Ideal for Autobahn Summer Cruising for larger motors with long 1303s gearing.
Overcome the asthmatic problem with splits, and force cool air into the engine bay, aiding cooling and performance.
Fasten or remove in a couple of minutes.
Three brackets clip into the vents,
and the shell is fastened to the brackets clamping the assembly together.
Estimate around the same price as the late scoops £65. I'm looking for 10 names down on these to get the first batch rolling.
vwbuzzers
Re: kühlspeed Ram Air Scoops (50 - 63)
Post by vwbuzzers »
No need to ask pal :wink: Nice to see how you got round the initial problem :wink:
Amended post pic of them now painted and fitted :wink:
vwbuzzers
Post by vwbuzzers »
vwbuzzers wrote:No need to ask pal :wink: Nice to see how you got round the initial problem :wink:
ps
Will pm you my bus colour :D
shaggy66bus
Post by shaggy66bus »
top work mike.
ill be wanting a pair pls
shaggy66bus
RUTLAND HARDCORE CAMPING POSSE 2005/06/07/08
http://www.rulowenough.com
massivesplitproject
Post by massivesplitproject »
what finish will these be in bare steel?
dsbus
Post by dsbus »
massivesplitproject wrote:what finish will these be in bare steel?
I was thinking 1.5mm mild steel to keep price down, (bare or primered).
I will also get a price for them in aluminium.
jerrythegerman
Post by jerrythegerman »
Have to say, these are top quality and have seemed to introduced a fair amount of additional cool air into my bus. Was having a few problems with engine bay temps and these have deffinately helped, I'm seeing 10 deg reduction in oil temp so must be better in actual air temp in the engine bay now.
Mine's running a turbo, so that engine bay get's hot. Got to be close to ultimate test so can only be better still on a N/A bus.
Though I only know mike through buying these, I have no issues with a well deserved plug. Oh, and I didn't get them cheaper or free for saying this!!
"It's rust Jim, but not as we know it"
switch3sixty
Post by switch3sixty »
I'll put my name down for a pair please, although i might need two pairs but will hold off on the second set due to cash flow for now...
Anton
Paint Scrapers, Danson Park, 4th Wednesday of the month
Grill-n-Chill 2016? Yep it's the 16th to the 18th of September ;)
bushi
Post by bushi »
2 questions will these fit my '65, and will you ship overseas? :) cheers, bushi
gingerdog
Post by gingerdog »
Bushi see mike (ds bus) other thread for items that'll fit your 65.
Put me down for a pair please mike
SBS #31 UK
152 ponies at the wheels.......and I killed them all
massivesplitproject
jerrythegerman wrote:Have to say, these are top quality and have seemed to introduced a fair amount of additional cool air into my bus. Was having a few problems with engine bay temps and these have deffinately helped, I'm seeing 10 deg reduction in oil temp so must be better in actual air temp in the engine bay now.
i had the steering box lift kit and you are correct about the quality of workmanship from dsbus
put me down for some please bare metal is good for me can leave em to rust to match rest of bus lol
vwbuzzers
Post by vwbuzzers »
That's good to here mate, hope alls running well with the big one in the back.
subwestyjon
Post by subwestyjon »
Ill go for a set of these please.
Glyno
Post by Glyno »
I would love a set. Pls let me know when you have a price worked out.
Thx
Glyn.
vwgillybilly
Post by vwgillybilly »
I'd be interested in a set in Aluminium please? Would have a set in steel though if that's the only option? These would be the ideal solution for getting extra air into my intake pipe.
Keep me posted.
Cheers.
Gill.
1994 993 911
1967 SO42 tintop
