1966, RHD, Walkthrough, Custom Camper.
Jenni
Re: 1966, RHD, Walkthrough, Custom Camper.
Post by Jenni » Thu Jan 12, 2012 11:39 pm
jellibus wrote:That's one hell of an oven :D I'll know where to come to cook my pizza :D
Would love a walkthrough :wink: So quite jealous :cry:
Oooops just caught the rest of the pics :o
Another fantastic resto job going on - total admiration :wink:
Hi. A few years ago I replaced the old oven with a newer one, now hinged on the back of the passenger seat, to allow for standing outside and cooking, also lifts off and can go anywhere, 2 rings grill and oven - very useful.
Crazy curtains went too. Oh, and a portaloo where the old oven was. All mod con's!
Walkthrough is definitely very nice to have, but I'm hankering after a flipseat (just a little bit!)
It's not a full resto, just enough to get through an MOT, more welding will be needed in the next few years. (all 4 wheelarches. rear corners, battery trays etc)
not the best pic, but more recent interior -
NEW YEAR HARDCORE CAMPING POSSE 2005/06/07/08/09/10/11
Euro road-trips: 2012; 10wks/3394miles. 2014; 4wks/3216miles. 2016; 6wks/4120 miles.
Jenni
Post by Jenni » Wed Feb 29, 2012 10:42 pm
We've (ok, mostly Jim!) made some more progress -
all looking good
sill strengthener all in
another hole filled in
how many holes in the floor!
wooo, floor welded in
bother, another bit to sort before the MOT
a previous lazy patch just dumped over rust, with a good amount of filler and newspaper, nice.
Post by vwJim » Tue Mar 13, 2012 11:59 pm
Bit more progress over the last two days. Some very basic filler work etc. Rear wheel bearings replaced, brake shoes replaced, rear wheel camber improved, link pin adjusted.
Quick blow over to stop the moisture getting to the new metal.
Ferry date is getting closer, wish the job list was getting smaller....
Supplying quality in house designed items plus parts from SCAT, Kennedy Clutches, CB Performance & FIRETEC. Also fitting service including modifications & mechanical upgrades.
Post by vwJim » Wed Mar 13, 2013 9:50 pm
A year to the day later & many miles in between the rebuilds, more work happening to the bus.
Rebuilt gearbox, mid-mount & new modified stock cradle all being fitted in a dry run. The old CE frame horns & the OG hacked cradle were removed first.
Eternal Optimist
Post by Eternal Optimist » Wed Mar 13, 2013 10:24 pm
Top work Jim
Post by vwJim » Wed Apr 03, 2013 6:30 pm
First of many trial fits of the engine. It used to lean over to one side and low due to a bad IRS conversion. Now sits square & level.
So the donor OG cradle, (thanks to Rick @ Schofields for supplying & Brian for collecting) is now welded in.
While removing the OG bump stops & shock mounts some more thin areas were found, so they were cut out.
Seam sealed & shultz'd then new brake lines & fuel system back in.
Some areas at the front were not done during the main welding exercise so picked these up now too.
And finally the bus feels like its going back together, dash wired back up, pedals restored & refitted, heating ductwork double insulated & shiny new adjustable IRS, (modified Porsche A-arms) & rear disks (CSP) going on.
Post by vwJim » Wed Apr 03, 2013 6:32 pm
Eternal Optimist wrote:Top work Jim
Thanks.
Can you spot your old parts? A-arms / stub axles / nose cone body panel (that got robbed from the pickup)
Post by vwJim » Thu Apr 04, 2013 9:41 pm
Post by vwJim » Thu Apr 11, 2013 4:19 pm
Engine finally in for good.
Indicators relocated down into the headlights.
A million other jobs, some unexpected like having to cut off the wheel arch bumper mounts from the NEW arches as they didn't line up with the front bumper preventing it from being fitted, that's despite the welder having the bumpers to do alignment tests... and starter motor decided not to work correctly after its winter hibernation.
But the good news, new MOT!
cloudinspector
Post by cloudinspector » Tue Apr 16, 2013 11:02 pm
Top work Jim, don't suppose you fancy relocating up north ;-))
Were the link rods long enough on the csp linkage? When Pete burgess set the carbs up on the 56 he nearly ran out of thread on the rods
1956 PANEL
2009 62' tug style narrowboat (home)
http://www.narrowboatmervyn.blogspot.co.uk
talk is cheap but shouting's free
Post by vwJim » Wed Apr 17, 2013 7:59 am
It all depends on what carb's & manifold you use.
On some setups the linkage works fine, on others not so good. Jen has throttle bodies so that linkage doesn't really suit them as the push/pull action is all wrong when coming off idle which is when you need it to be silky smooth. So that's on the cards for a redesign once everything else is sorted.
Post by vwJim » Wed Nov 19, 2014 11:53 pm
Some work to Jen's this year when we've not been working on the Pickup.
Shame the shot blaster warped the panel on the new tailgate, but you live and learn.
New etch primed then sealed with white.
New and old.
johnharte
Post by johnharte » Fri Aug 10, 2018 3:10 pm
Whatever happened to this one?
Using Tapatalk
Jenni
Post by Jenni » Fri Aug 10, 2018 3:29 pm
Just home from holiday in Netherlands in it.
Lots been done in last 4 yrs, but terrible lack of thread update im afraid!
Post by vwJim » Sat Aug 11, 2018 10:07 pm
Also you signature is missing some trips
