Engine rebuild
frilly
Engine rebuild
Post by frilly »
Good evening ,does anyone know of a company that could rebuild the bottom end on my 1500 sp engine near to stamford lincs? Kind regards neil
Stevep
Re: Engine rebuild
Post by Stevep »
Vw aircooled works
frilly
Re: Engine rebuild
Post by frilly »
Where are they based, do you know?
Stevep
Re: Engine rebuild
Post by Stevep »
Spalding just google
Vw aircooled works
Pete shaw
frilly
Re: Engine rebuild
Post by frilly »
Oh brilliant thank you
Banger
Re: Engine rebuild
Post by Banger »
Evening mate, bit of a trek but I would recommend giving Danny Wharton at Reichspeed a call; he's up near Gainsborough.
frilly
Re: Engine rebuild
Post by frilly »
Hi mate , to be honest I think the bottom end is to far gone. Had a quick look tonight and when you turn bottom pully it is really bad so I suspect cases will be destroyed
Re: Engine rebuild
frilly wrote: Fri Jun 26, 2020 9:09 pm Hi mate , to be honest I think the bottom end is to far gone. Had a quick look tonight and when you turn bottom pully it is really bad so I suspect cases will be destroyed
In what way bad?
frilly
Re: Engine rebuild
Post by frilly »
Hi jim , with the fan belt off there is so much play when you turn the bottom pully left and right you can hear it knock
Re: Engine rebuild
I wouldn't right the case off without opening it up.
frilly
Re: Engine rebuild
Post by frilly »
True. Gona drain the oil when I get a minute and see what deverstation I find!
