I believe that these are ‘mesh grey’ although am sure I’ll be corrected if they aren’t
As they are original, they’re in well used condition as follows:
Drivers Seat: no tears to seat surface, but minor tear on side of the seat cover.
2/3 passenger bench seat: has a minor tear on the seating surface of the base cover, partially along the seam and then at a 90 degree angle not along a seam. The back rest cover does not have any damage and is on great condition.
These tears could be repaired, or they make a very useable set of original covers.
I also have the 3 of the 4 original horsehair/ coconut type pads/ cushions as follows:
1) drivers base
2) drivers back test
3) 2/3 bench base
NOTE: the seat frames are not included, 4x covers and 3x pads only.
Sold as a set, £199 for the lot.
Thanks,
Will
