Slough/Newbury Swap Meet Parts
eastwood
Post by eastwood »
Bus spring plate bushes - £5 a pair
Bosch Regulator - £10
Dizzy - Taken on my running bus as switched back to Vac advance, weas working fine when removed - £30
SWF Rear Light covers - £20
Bat Dash Blank - £5
early bay Tailgate Lock Mechanism - £20
Copy Bosch 044 Fuel pump - kept as a spare for a scooby project that never happened - £35
Various fuel pumps - £5 each
Chrome breather - £5
early bay outer rear hub bearing 68-7/70 - £10 each
Beetle Generator Stand - £10
Bocal 34 pict 3 carb - was kept as a spare came off a running car - £60
Bay window Circlip for inner rear wheel bearing Bus 64-79 - £5 pair
Rear Main seal £5
T25 distributor cap MV/SR/SS/ 2.1 8/84-91 - £5
Oil cooler Block off - £5
Complete set of silverline engine bearings 0.25mm - £15
Various Beetle switches - Headlight / Hazzard / Wiper - £5 each
External oil fileter bracket & Filter - £5
Bug carpet set - £10
KYB Gas Shocks (41cm extended-28cm collapsed) - £30 Pair
Late Karmann Ghia Bonnet - £30
Sun Canopy - £50
Early Bay Heater Cable - £5
#### Pictures here ####
https://www.dropbox.com/sh/8g2nmips0pqa ... Mq-7a?dl=0
