Broken Down
Dot
Broken Down
Post by Dot » Sat Oct 05, 2019 1:43 pm
Hi all, I’ve stopped to assist a chap in a 65 bus, and it’s died. Starts after about 10 mins however feels like it’s flooded, once that goes away it runs fine.
Until you go to drive and after 5 mins or so under load we are dead again and back to square one.
009 Distributor, points and condenser.
I’m at the end of my knowledge - I don’t think it’s ignition though.
Carb is Solex h30/31 pict, unorthodox spring from previous breakdown.
Appreciate any help,
Dot
'59 import Mango... plus a liberal sprinkling of rust....
richandsue
Re: Broken Down
Post by richandsue » Sun Oct 06, 2019 12:42 pm
could be fuel pump failing. not delivering enough fuel, hence after a few miles runs out of fuel. then when you are cranking the engine fuel is gradually filling the carb back up. then you get going again. just a thought though. :cheers:
j0hn
Re: Broken Down
Post by j0hn » Sun Oct 06, 2019 7:33 pm
When did they last have a run out in it? It might be the colder weather causing carb icing.
I had similar issues years ago when I first got my bus - it has the same cheap pancake air filter on it, which caused carb icing after around 10 minutes of driving. It wouldn't start straight away, bit would be fine after a few minutes rest. Then you'd set off again and repeat the process.
I ditched it for a set of twin carbs instead, but a proper oil bath filter would be just the job too.
Re: Broken Down
Post by vwJim » Sun Oct 06, 2019 10:14 pm
Similar to above, if the fuel filter is blocked or the isn't vented it'll cause that.
Dot
Re: Broken Down
Post by Dot » Mon Oct 14, 2019 9:13 am
Chaps got sorted bus recovery, unsure what the problem is/was still. Thanks for responses.
