Wanted - Stock 1500cc distributor
mountainbus
Post by mountainbus » Sat Aug 31, 2019 7:01 am
I'm looking for a stock distributor as fitted to 66/67 1500 engine. Part number 131 905 205
Banger
Re: Wanted - Stock 1500cc distributor
Post by Banger » Mon Sep 02, 2019 5:55 pm
Slough/Bracknell would probably be your best bet, although you could use a 113-905-205K. Timing is the same at 7.5 degs BTDC. Assuming you are using a Solex 30 pict 1 with the "power jet"?
Rocket Ron
Post by Rocket Ron » Tue Sep 03, 2019 12:16 pm
If you want a stock dizzy then you'll need NOS cap, rotor arm and condenser ....."..................maybe..
I'll check to see if I have that number..
Ron
mountainbus
Post by mountainbus » Wed Sep 04, 2019 8:42 am
Can't get out to shows or swapmeets unfortunately, so Rocket Ron, if you could check if you have one I would appreciate it.
welldoneade
Post by welldoneade » Thu Sep 05, 2019 12:13 pm
Hi,
I have a 111-905-205 M which apparently was used on Feb’64 - ‘67 beetle and bus engines if you’re interested.
I’m fairly sure this came off the 1500 that was in my old ‘65 bus.
Rocket Ron
Post by Rocket Ron » Thu Sep 05, 2019 4:27 pm
I've mailed him with the correct one but no reply.....
Ron
mountainbus
Post by mountainbus » Fri Sep 06, 2019 6:33 am
Pm's sent to rocket ron and welldoneade. Maybe I didn't send them correctly, so let me know on here if thats the case
mountainbus
Post by mountainbus » Wed Sep 11, 2019 5:26 am
Sorted. Thanks rocket ron & welldoneade
Rocket Ron
Post by Rocket Ron » Wed Sep 11, 2019 6:24 am
Will get this in the post, if there are any other small bits you need I'm here to help.
Cheers Dave
Ron
