Early bay brake drums on a splitty
BigRob
Post by BigRob » Tue Jul 02, 2019 7:58 pm
Hi all
I’ve been looking at early bay brake drums for my splitty,
I understand that the spindles are different. Mine are stepped and the early bays are tapered (correct me if I’m wrong please). Does anyone know if if the drums meant for the tapered ones would fit on the stepped ones?
The reason I want to do this is a have some alloys I want to put on her and they won’t go over the current drums.
Rob
Re: Early bay brake drums on a splitty
Post by vwJim » Wed Jul 03, 2019 9:09 pm
Its a year change. Yours are early's / later are different. Bay are slightly different again but can be used with conversion parts.
BigRob
Post by BigRob » Tue Jul 09, 2019 8:52 pm
What sort of conversion parts would I need? Could I just change the bearings, or is it a bit more complicated?
Post by vwJim » Thu Jul 11, 2019 7:46 am
You can't. Yours are earlies.
You can only make them fit on later spindles with a conversion, but it's pointless as they don't give any benefits over stock late split brakes.
