Gear box nose cone
Chrispduck
Gear box nose cone
Post by Chrispduck » Fri Jun 14, 2019 5:24 pm
Hi all does any one know if I can take the nose off the gear box in situ or has it got to come out thanks
Re: Gear box nose cone
Post by vwJim » Fri Jun 14, 2019 7:40 pm
It would be a right PITA to try do that.
Chrispduck
Post by Chrispduck » Sat Jun 15, 2019 8:23 pm
[attachment=0]DSC_0337.JPG[/attachment
Chrispduck
Post by Chrispduck » Sat Jun 15, 2019 8:25 pm
Managed to do in situ but whats going on in my gear box looks like water ingress
Post by vwJim » Sun Jun 16, 2019 9:47 am
Have you managed to remove the nosecose completely, or just unbolt it and look inside?
Chrispduck
Post by Chrispduck » Sun Jun 16, 2019 12:56 pm
I had to disconnect the rd box's if I had disconnected the brake flexes it would have came out
Chrispduck
Post by Chrispduck » Sun Jun 16, 2019 1:01 pm
It turns out the thick nasty sludge was stopping forth from being selected so when I actually got forth I recon the sellector moved hence I couldn't get it out of forth I can select all gears now and quite smoothly
Post by vwJim » Sun Jun 16, 2019 1:55 pm
That's a result.
PITA to do with all the gearbox / brakes etc attached.
Think I've got that job to do, as I think the hockey stick has snapped. Thankfully its an IRS bus, so it could all slide back easier than yours as loom as all the loom / EFI connections have enough slack.
Chrispduck
Post by Chrispduck » Sun Jun 16, 2019 7:14 pm
Your right when your on your back in the rain it always a pain in the azz I'm allways keen to help if you need
