Red9design outer steering column
58splitty
Post by 58splitty » Sun Jan 13, 2019 2:19 pm
Hello,
Just a quickie, on the outer column it has a needle bearing in one end, does this go at the top near the steering?
1958 splitscreen
Re: Red9design outer steering column
Post by vwJim » Sun Jan 13, 2019 6:46 pm
Yes.
58splitty
Post by 58splitty » Sun Jan 13, 2019 9:24 pm
Thanks Jim
1958 splitscreen
58splitty
Post by 58splitty » Thu Jan 24, 2019 8:34 am
The spring which originally went under the steering wheel on the column, is this needed with the new column or does this now become redundant?
1958 splitscreen
Post by vwJim » Thu Jan 24, 2019 8:56 am
I guess the fitting instructions haven't improved much ;-)
I can't remember. If the column retains the factory style bearing + collar, then the spring in definitely required as the spring pushes the collar into the gap in the bearing to eliminate movement.
