Rocker shaft mounting block + conrods - stock
Post by vwJim » Mon Jan 07, 2019 10:49 pm
Over Christmas I had a tidy up and decided I had far too much stuff sitting around not being used, so I've been tinkering with an old engine that was broken down years ago / no history of it.
In the cleaning up I've found one rocker arm oil gallery is blocked, which I suspect caused the closest mounting block to crack.
So I'm after a stock rocker shaft mounting block. Possibly a stock rocker arm too, (I've not stripped it fully to see if it's salvageable.
Also, this engine is missing its conrods, so if you have a set / part set that are gathering dust I'd be interested please.
Paul L
Re: Rocker shaft mounting block + conrods - stock
Post by Paul L » Tue Jan 08, 2019 7:39 am
What size motor is it? I have the spare rocker bits you need and some conrods. £20 posted
Post by vwJim » Tue Jan 08, 2019 9:44 am
Its a 1641cc as it's had the conversion B+P's fitted in the past. Single port heads.
If your parts match, that sounds good to me.
Paul L
Post by Paul L » Tue Jan 08, 2019 8:02 pm
Yes Jim they will fit your motor. Will pm you
