mexican engine
frilly
mexican engine
Post by frilly » Tue Dec 04, 2018 6:45 pm
hi all , can anyone tell me what size are Mexican engines , as numbers have been rubbed off, also what distributor would be needed ? thanks neil
Re: mexican engine
Post by 8 8US » Tue Dec 04, 2018 9:45 pm
Neil
You simply can’t tell from the outside, even if it had a code on the barrels/pistons could be changed, so from the outside they’ll look the same, 1300, 1500, 1600, 1641, 1776, etc all look the same!
Image search here:-
https://www.google.co.uk/search?q=vw+ai ... AnoECBIQAg
Re: mexican engine
Post by 8 8US » Tue Dec 04, 2018 9:49 pm
frilly
Re: mexican engine
Post by frilly » Tue Dec 04, 2018 10:39 pm
I guess ill never know what ive got then . thank you for your help guys
andydlc
Re: mexican engine
Post by andydlc » Fri Jan 11, 2019 10:33 pm
The original Mexico fuel injected engine used in later production was a 1584cc - what is the motor from?
frilly
Re: mexican engine
Post by frilly » Fri Jan 11, 2019 10:58 pm
hi andy , the motor came over from Canada with my 56 single cab ,
Re: mexican engine
Post by vwJim » Sat Jan 12, 2019 9:52 am
Those engines are easily spotted, as they don't have fuel pump hole in the top of the case.
