Need help setting up 34 pict 3
BigOldMac
Post by BigOldMac » Fri Jul 13, 2018 2:32 pm
Anyone in the Bedford area able to help me set up an EMPI 34 Pict 3 carb? Just been fitted, was running fine but stalling at idle, then I've tried adjusting it and now it's not doing the job :oops: more than happy to pay for your services, but a bit desperate as I have a long journey for a weekend away planned next week...
Devaluing my VW's every day
'67 Split
'65 21w Samba
'56 Oval
dj-paul-c
Re: Need help setting up 34 pict 3
Post by dj-paul-c » Sat Jul 14, 2018 7:14 am
I had an empi carb in the past
They have slightly different settings than a normal carb -
I.e it's not just the normal 4 turns out to set
You either have to turn the idle screw right out or right in and start from there , turn to adjust till it's nearly off and 1/4 turn back
(I think )
BigOldMac
Post by BigOldMac » Sat Jul 14, 2018 8:46 am
Thanks, will give it a try
'67 Split
'65 21w Samba
'56 Oval
