Faulty wiper motor
Taffy
Faulty wiper motor
Post by Taffy » Tue Jul 10, 2018 11:48 am
My wiper stopped working. Having removed the motor Icould see that the spring holding the two contacts had broken. Water had seaped into the casing cos of a leak through the washer jets. Have cleaned rust and the spindle turns freely. Can I get a new spring for the motor - if so where can I get one from and is there any cleaning agent or oil I should spray on the inside of the motor.
David
BJ1
Re: Faulty wiper motor
Post by BJ1 » Sun Jul 15, 2018 8:18 am
Take the armature out and clean everything especially the commutator. Any small spring will work - I use the ones from ball point pens - but remember that one end of the spring hooks on via an insulated washer or the spring will create a dead short and vapourise!
1966 Westy in Velvet Green - being restored
1967 Sundial from Idaho
1971 Westfalia from LA
