67 11 window aka Pete
BlastingDiePast
Re: 67 11 window aka Pete
Post by BlastingDiePast » Wed Jun 20, 2018 7:06 pm
type21f wrote:
Wed Jun 20, 2018 6:21 pm
Nice US truck..
It is isn’t it, matches my 43 jeep.
Post by type21f » Wed Jun 20, 2018 7:14 pm
Truce?
I hope so...
BlastingDiePast
Post by BlastingDiePast » Thu Jun 21, 2018 10:39 am
White colour coded primer applied ready for 2k paint on the inner areas.
BlastingDiePast
Post by BlastingDiePast » Fri Jun 22, 2018 9:25 pm
Finally the inner areas are 2k top coated and the new panels blasted and primed ready for welding.
BlastingDiePast
Post by BlastingDiePast » Thu Jul 05, 2018 9:11 pm
Top hats, Jacking points, gear tube, handbrake tube, inner and outer B post (passenger), inner B post (drivers), long panel lower supports, passenger rear wheel tub, C post and both rear D posts welded in or repaired.
Long, short panels and rear corners welded in and the cargo floor.
BlastingDiePast
Post by BlastingDiePast » Wed Aug 15, 2018 4:39 pm
Working hard on Pete still (and the others)
Long/short/corners/front floor/front arches/ kick panel all welded in, primed etc
BlastingDiePast
Post by BlastingDiePast » Thu Oct 25, 2018 5:29 pm
Gaps!
BlastingDiePast
Post by BlastingDiePast » Thu Oct 25, 2018 5:50 pm
Primer...
Blocking...
Ready for paint.
BlastingDiePast
Post by BlastingDiePast » Mon Oct 29, 2018 1:04 pm
Painting...
BlastingDiePast
Post by BlastingDiePast » Tue Oct 30, 2018 10:11 pm
Just before 5 months since its arrival the shell is painted.
BlastingDiePast
Post by BlastingDiePast » Wed Nov 07, 2018 8:51 am
With the 23 in the booth drying out we had a time to start bolting on the doors etc
BlastingDiePast
Post by BlastingDiePast » Tue Nov 13, 2018 5:50 pm
Getting ready to install the headlining and window trim.
The bus is sat in the booth nice and warm to stretch the material.
BlastingDiePast
Post by BlastingDiePast » Thu Dec 13, 2018 5:49 pm
Moving on to the chassis.
So the bus is having a large engine fitted which means it’s having an oil cooler, a concept racing oil filter! But with belly pans this causes a fitment issue, so here is what we have done.
First a custom top housing with a rear scoop, then to the bus and modify the rear crossmember so it fits.
Next box in the crossmember and weld in the top housing.
Tomorrow we’ll be modifying the centre belly pan to accept the oil cooler and make the whole job look smart.
Post by vwJim » Fri Dec 14, 2018 9:11 am
Nice to see air path out of a cooler been thought about.
BlastingDiePast
Post by BlastingDiePast » Fri Dec 14, 2018 2:18 pm
Over thought more like, hours of test fitting and modification to get a simple air duct design and welded in.
So the belly pan has been cut and extra support will be welded to the cut edges for a little more strength (these pans like to twist a lot), with the cooler fitted on the duct it still hangs low enough to catch air and not cause a issue.
To the rear of the duct I’ve made an exit scoop pushing the air down so hopefully it will not flow back up to the dog house oil cooler vent on the engine. (Well that’s the idea what it really does we’ll never know...) below the exit duct is where the oil pipes and electric wires will go and this has a cover plate (yet to be drill as we don’t have the oil pipe work yet).
The belly pan and cover plate will have rubber backing installed to help keep water and dirt out.
