67 11 window aka Pete
BlastingDiePast
Post by BlastingDiePast » Tue Apr 03, 2018 9:23 pm
In for the works! Plus a few upgrades
It’s had a whack or two over the years, plus it was a wood storage bus in Sweden for many years before ending up in Wales via FBI and then to its current owner many years ago. Used as it should be it’s time for a refresh.
BlastingDiePast
Re: 67 11 window aka Pete
Post by BlastingDiePast » Wed Apr 04, 2018 8:17 pm
Slowly it’s all coming off...
BlastingDiePast
Post by BlastingDiePast » Fri Apr 20, 2018 6:34 pm
Ready for a prime.
BlastingDiePast
Post by BlastingDiePast » Sat May 19, 2018 8:52 pm
And some IRS action.
Had to remake the frame horn cradle mounts and a section of the cradle plus straighten both lips.
BlastingDiePast
Post by BlastingDiePast » Fri May 25, 2018 6:13 am
More cutting and removing old repairs.
flojo
Post by flojo » Mon May 28, 2018 10:27 pm
Nice work BDP, looks like youve got a relatively solid bus there.
Keep up the work, I will be watching closely as our bus is undergoing a make over as well :)
RM
Project 1966: https://www.ssvc.org.uk/phpbb/viewtopic ... 8&t=121834
VW Splitscreen, 1966 RHD, Devon Roof, Dormobile Interior
Creative Engineering IRS Kit
BlastingDiePast
Post by BlastingDiePast » Tue Jun 05, 2018 5:42 pm
Removing old patch work welding and rot, new chassis leg sections and seat support panel fabricated and welded in.
BlastingDiePast
Post by BlastingDiePast » Sat Jun 09, 2018 7:58 am
Getting Pete looking like a bus again.
New...
Inner valance
Lower A post’s
Cab floor
Kick panel
Front arches
Lower bulkhead
Inner B post sections both sides
Outer O/S B post
Chassis sections front inner and outer
Rear chassis sections
Cross members
Out riggers
Jacking points
I beams and top hats
Heater tube
Cargo floor
O/S wheel arch
O/S battery tray and engine tin
O/S rear corner.
BlastingDiePast
Post by BlastingDiePast » Sun Jun 10, 2018 7:36 pm
And photos
BlastingDiePast
Post by BlastingDiePast » Sun Jun 10, 2018 7:37 pm
More
BlastingDiePast
Post by BlastingDiePast » Sun Jun 10, 2018 7:38 pm
More
BlastingDiePast
Post by BlastingDiePast » Sun Jun 10, 2018 7:39 pm
Last ones
BlastingDiePast
Post by BlastingDiePast » Wed Jun 20, 2018 5:42 pm
With the chassis areas repaired and the new I beam’s top hats and other sections welded in its off to the blast room then primer.
BlastingDiePast
Post by BlastingDiePast » Wed Jun 20, 2018 5:44 pm
Ready for the new upper panels to be welded in.
Post by type21f » Wed Jun 20, 2018 6:21 pm
Nice US truck..
