3 devon Awning rails ? Advice please
Fuch77
Post by Fuch77 » Wed Aug 02, 2017 10:48 am
I have kept all the parts that ever got broken replaced or just feel off my Devon 67.
It was so many years ago i can not remember where on the van they came off.
Now the time has come to have them all repaired and put back on the van i find i have three awning rails?
Can anyone say why?
i can think two could have gone on the roof on each side and the third seems to have some over spray from the lower body colour .
Making me think it was low on the van some place.
Can anyone shine some light on this please?
Re: 3 devon Awning rails ? Advice please
Post by 8 8US » Wed Aug 02, 2017 11:12 am
One on the roof, one below the doors (for the awning skirt?) and one behind the front seats for the hammock.
G will be along in a bit to correct me!
1960 Single Cab Pickup
1966 Devon
1980 Brasilia (for sale!)
Post by clymoj » Wed Aug 02, 2017 7:01 pm
^^^ WHS is my understanding yes
I think the roof is usually more of a I( shaped profile and the sill below the doors is more of a [ shaped profile
Post by clymoj » Wed Aug 02, 2017 7:02 pm
and yes below the doors is for the awning skirt, I think you should have poppers over the rear wheel arch for that too
Post by type21f » Wed Aug 02, 2017 7:42 pm
Did someone call?
OK..
I want to buy some OG rails..
IIRC would need to check...
Roof rail for a standard day awning is 82"
Rail below cargo doors is 59".
Cross van transverse cot rail is half a roof rail at 41"
The correct profile is with an almost flat base..(slight curve) and the sides are square up from the base..curving over at the top. The gap is around 3mm with predrilled holes in the base which are countersunk.
In order to fit the fixings there is a larger diameter hole.
The bus as supplied was painted. The rail unpainted.
My MY 65 Caravette original paint came with a Devon tent and has an extra long rail on the roof attached with screws.
My MY 64 Caravette roof rail was riveted in place. My 64 had been repainted and the rails sprayed as well.
They were stripped and polished and fitted.
The lower rail is filed and shaped to meet the wheel arches.
I sat my rail on caulk and fitted it with stainless countersunk slotted cushion bolts and nylon nuts before re the headlining was fitted.
My vans have poppers round the wheel arches for the awning skirt...
And Devon steps..
Depending on the length you bus may have had Devon tent or a rail fitted on cab side of division..
Fuch77
Post by Fuch77 » Thu Aug 03, 2017 2:12 pm
Seems they have the same profile?
Hopefully you can see from the photo (my first upload on this site)
two are 83 " or 215cm and the third is 63" or 160cm and can see the sea blue pray.
does this shine any more light ?
Fuch77
Post by Fuch77 » Thu Aug 03, 2017 2:14 pm
And many thanks for the detailed reply so far
Post by ted698 » Thu Aug 03, 2017 2:59 pm
They are the same profile as my roof mounted rail (1967 Devon) - Graham (Type21f) wasn't sure about my profile he thought it should be square'er - but Devon had a habit of using anything they could find....
Graham - I wasn't aware that rails (even roof?) were not painted when leaving Devon factory - only bare alloy? - really?
Fuch77
Post by Fuch77 » Thu Aug 03, 2017 3:10 pm
Ok so it seems that one 83"above the door and the 63" below.
where was the third 83" again please?.
Also what would you recommend to resto them ?
Post by type21f » Thu Aug 03, 2017 3:10 pm
I have had lots of discussions on this..
Strangely this makes sence to me.. Devon fitted them unpainted..but usef different fixings.
If they fitted a pop top fit thry coulf fit machine screws. Never checked if mine are dlottef countersunk screws or machine screws on my 65 with MW pop top!
Said they werr screws but now not sure!
If a Tin top drill hole use rivet..
My 64 was s Tin top but a PO fitted the aftermarket Gentlux.. so that rail was rivetted. Had access st resto to fit what I wanted!
On my 65 I have a Devon Tent rail.
The bus is OG paint except an impact repaint at the rear bumper level.
Never repainted just tarted where damaged or rotten..
65 Cill was repainted with house paint so paint on cill rail but no OG paint on roof rail.
On the 64 the roof and lower had both been repainted.
So upper rail had upper colurway paint on it..
Lower rail wad painted but different hue..
Both had faded and peeled a little?
No I think paint got on rail on the 64 over the years at repaint!
Who knows!
It makes sence to me that Devon would fit rails unpainted
Post by ted698 » Thu Aug 03, 2017 3:21 pm
My tintop it is riveted on...
Post by 8 8US » Thu Aug 03, 2017 3:23 pm
And mine.
[feeling left out of all the Devon action going on today]
1966 Devon
Post by type21f » Thu Aug 03, 2017 3:24 pm
That would agree then..
I have no idea why a third rail..
Maybe PO had Tent one side and Day awning the other!
oeeer Where are your holes!
LOL
Post by type21f » Thu Aug 03, 2017 3:26 pm
Every day is a school day...
Laptab Kingsbury road as a wheel powdercoater..
Sent from my SM-G930F using Tapatalk
Fuch77
Post by Fuch77 » Thu Aug 03, 2017 3:51 pm
Sadly my holes were plugged so long ago i can not remember.
I for sure remember the one above the cargo door...vaguely remember the one below it.
Would the low one be fitted above the deluxe trim? and can anyone link me to a photo of that as i was thinking of re fitting them ?
Maybe it did have one both sides?
I do NOT remember any holes in the roof where it would have come off on the opposite driver side.
i may have to dig out some some very old hard copys of photos from the early days and study them
