Double Cab external seams
Jon Petts
Post by Jon Petts »
I am about to fit new rear wheel arch panels to my double cab.
The external seam at the front edge of this panel is folded over and spot welded.
When I removed the original panel there seemed to be a few spot welds but due to rust within the seam it was impossible to tell if these spot welds were done before it was folded over through two layers, or after being folded through all three layers of panel.
Does anyone know?
Doka Dave
Re: Double Cab external seams
Post by Doka Dave »
You got a picture of where you mean?
I can check for you!
DD
Member since 1996.
Jon Petts
Post by Jon Petts »
I haven't got a photo but its the seam that goes outwards at the front edge of the rear wheel arch panel, which is level with the end of cab,it goes from front of pick up bed to sill
