Require Coloured Wire key for Wolfsburg West Indicator Switch with dim/dip 8/65-67
R32GUY
Post by R32GUY »
HI fellow SSVC members..
I recently had a bit of an electrical issue - and witnessed a bit of a loom fire (thankfully I witnessed it) - The issue was it appears my stalk mounted dim/dip switch and indicator circuit was shorting out on something or together. - I tried to repair the burnt wires - but couldn't get my stalk mounted dim dip to work.
Our bus is a 1966 Australian import microbus..
Anyway I decided to purchase one of these Wolfsburg West replacements from Alan Schofields at Slough Swap Meet, trouble trouble is no-one appears to have published a wiring diagram that match the number of cables I have. - The chaps on the stall suggested I look on the Samba or follow existing diagrams
Complete Indicator switch 8/65-67 with built in dipswitch. 8 wires as per US specification, but also works fine on european buses (please call for wiring details in this case)
http://www.alanhschofield.com/ourparts/ ... 3513F.html
The chap I bought it from on Sunday suggested I check out the Samba and http://www.type2.com -but I'm struggling to make a correlation to what I have one my stalk, I tried to call Schofields today and there was no answer..
So wondered if any of you guys had any suggestions or help to offer?
1966 RHD Australian Kombi - Sandgreen & Mango 'Bernie'
1959 T14 Karmann Ghia 'Lola'
1971 T147 Brazilian Karmann Ghia TC
1992 Golf Mk1 Rivage
2013 Beetle 70's edition
2016 Audi RS3
R32GUY
Re: Require Coloured Wire key or Wolfsburg West Indicator Switch with dim/dip 8/65-67
Post by R32GUY »
Here are some pictures of the stalk / loom
What is really confusing is it has 9 connectors on it not 8
Two thinner 0.5mm wires towards the top of the loom
Blue
Brown
Then the following coloured wires:
Black/red
Black/green/white
Black/yellow
Brown
Black/Purple
BLack/White
BLack/Green
The details from this similar thread : viewtopic.php?t=72841
States the following -
1. Black with a white trace (controls front left indicator function)
2. Black with a yellow trace (controls left rear taillight)
3. Black with a green trace (controls front right indicator function)
4. Black with a red trace (controls right rear taillight function)
5. Black with a purple trace (input from brake light switch, the wire coming from your brake light switch is typically black/red)
6. Long black (input to turn signal flasher relay.To terminal 87b if using 4-way emergency flash system. If not equipped with 4-way emergency flash system, connect to Terminal 54 of original turn signal flasher or 49a if using a replacement turn signal flasher.)
Are these similar - and what do the thin blue and brown wires and thick brown wire do? - Presume the Black/Green/White wire must have something to do with the dim/dip circuit as well?
Thanks in advance for any assistance... I've sent an email to Wolfsburg West to see if they can help.... Coupled with this job I'm also considering wiring in a hazard switch that our bus didn't have when we bought it.
2016 Audi RS3
whathaveigoneanddone
Re: Require Coloured Wire key for Wolfsburg West Indicator Switch with dim/dip 8/65-67
Post by whathaveigoneanddone »
I have exactly the same question, what are all these wires for? Especially the blue and the brown....I'm looking at this utterly perplexed and can't understand why it didn't come with any form of guide! Help appreciated
rodntod
Post by rodntod »
Is your bus fitted with separate indicators and tail lights at the rear?
No, they are an integrated unit.
rodntod
Post by rodntod »
Sorry what i meant was,do you have orange indicators or us spec lights at the rear?
Ah ok, sorry - no it's orange indicators
rodntod
Post by rodntod »
Cool, then you are only going to use 3 of the wires for the indicators.
Black/white-front left ind.
Black/green-front right ind.
Black/green/white-common wire for ind(this will go to a relay/flasher unit along with a switched live and an earth)
Thinner blue wire -to ind telltale on the speedo
Thinner brown wire should be an earth wire
You can disregard the blk/red, blk/purp,blk yell as these are only used with us spec indicators and combined tail lights.
Thank you so much, I literally had no idea (like most things!) - thanks again
rodntod
Post by rodntod »
No worries, I was there once myself.
Ed
skipps
Post by skipps »
All sorted no help required 8)
Hi just found this thread as I'm just about to change my 67 ind stalk found your wiring instructions very handy but not quite understanding the switched live and earth bit are they already there, as there is only the thick brown wire that i'm not sure where this would go !! look forward to any help as this post is nearly 3yrs old
Skipps
SAVE THE PLANET ............its the only one with beer on
