1966 Devon Options
Bathtub57
Re: 1966 Devon Options
Post by Bathtub57 » Sat Apr 05, 2014 4:43 pm
type21f wrote:The V.A.A.C.C.U.U.M. President will no doubt give a full and correct answer but AFAIK...the drive away idea was that on the best solution, there is an .....umbilical piece which is attached to the van awning rail and this then zips to the awning...
So
Method 1) You put the awning up with the vertical side pointing to where you want to put the van and you attach the umbilical bit to the awning rail and then you manoeuvre the van to a pposition where you can zip up..
Method 2) You park the van where you want, you put the umbilical bit in the awning rail and then you zip the awning to it and put the poles up and tension the umbilical entry.
So when you want to drive away....you unzip...drive forwards and you can then take the umbilical bit off
and as it says in the Haynes manual assembly is the reverse of disassembly...
That makes sense. I suppose the question is what does this piece look like and where can I get a hold of it....
1966 Devon Caravette
My Vans Thread http://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=51495
Mark Paine
maddison
Post by maddison » Sat Apr 05, 2014 5:16 pm
usually about 6-8" wide with bead along either edge (so you use a figure 8 on your awning to attach the umbillical and the cord on the other side slides into your awning rail
Westfalia awnings came with these...you can buy them from most caravan spares...usually someone selling them at most shows too
Bathtub57
Post by Bathtub57 » Sun Apr 06, 2014 3:11 am
maddison wrote:usually about 6-8" wide with bead along either edge (so you use a figure 8 on your awning to attach the umbillical and the cord on the other side slides into your awning rail
Thanks, I'll go shopping!
Mark Paine
Post by type21f » Wed Nov 21, 2018 1:54 pm
Any biscuit tin loo pictures?
