1600 ADR Engine Rebuild
Harry UK
Post by Harry UK »
My case has spacers for the bearing nearest flywheel, see photo (I have turned spacer for visibility).
The bearing is snug on one half of the case but loose on the other, I haven’t tried with the case together but will try when new set arrives.
Is it normal to have a spacer and can replacements be purchased if bearing is loose?
Measurements:
Crank = standard
case = 0.5 mm
Re: 1600 ADR Engine Rebuild
Do you mean that was under the bearing?
If so, someone has bodged it in the past. Should never have spacers / shims under the bearing
Harry UK
Post by Harry UK »
Thanks for confirming Jim, as I suspected it’s not standard.
I’ll continue with rebuild and use it as experience as looks like a new case required soon.
Just use the correct size bearings
Harry UK
Post by Harry UK »
The case for the main bearing without shim is 67.5mm, I can only find 2mm oversize case for sale?
BJ1
Post by BJ1 »
Harry UK wrote: Sun Sep 20, 2020 10:47 am The case for the main bearing without shim is 67.5mm, I can only find 2mm oversize case for sale?
Blimey - that is a mega bodge! New case I'm afraid. Paul Luxton in Newton Abbot had some good ones recently.
1966 SO42 Westy in Velvet Green - on the road at last!
1967 Sundial from Idaho
1971 Westfalia from LA
