Wanted - Stock 1500cc distributor
mountainbus
Post by mountainbus »
I'm looking for a stock distributor as fitted to 66/67 1500 engine. Part number 131 905 205
Banger
Re: Wanted - Stock 1500cc distributor
Post by Banger »
Slough/Bracknell would probably be your best bet, although you could use a 113-905-205K. Timing is the same at 7.5 degs BTDC. Assuming you are using a Solex 30 pict 1 with the "power jet"?
Rocket Ron
Post by Rocket Ron »
If you want a stock dizzy then you'll need NOS cap, rotor arm and condenser ....."..................maybe..
I'll check to see if I have that number..
Ron
Sometimes when you have set the benchmark, the only one you have to beat is yourself !
mountainbus
Can't get out to shows or swapmeets unfortunately, so Rocket Ron, if you could check if you have one I would appreciate it.
welldoneade
Post by welldoneade »
I have a 111-905-205 M which apparently was used on Feb’64 - ‘67 beetle and bus engines if you’re interested.
I’m fairly sure this came off the 1500 that was in my old ‘65 bus.
Rocket Ron
I've mailed him with the correct one but no reply.....
Ron
mountainbus
Pm's sent to rocket ron and welldoneade. Maybe I didn't send them correctly, so let me know on here if thats the case
mountainbus
Sorted. Thanks rocket ron & welldoneade
Rocket Ron
Will get this in the post, if there are any other small bits you need I'm here to help.
Cheers Dave
Ron
