Doghouse extension
Breconbus
Doghouse extension
Post by Breconbus »
Hi
I am fitting a doghouse fan shroud for 1600 twin port. (1965 split screens) On the back there are two extra pieces to close off the oil cooler. One goes on the open side of the cooler and mates to the back of the shroud so totally closing off the cooler. The second piece goes on the bottom of the first piece and sticks out at 45 degrees- so ends inline with the side of the flywheel.-
Question is, can I now access the top bolt on my bell housing when fitting the engine? Looks like no to me
Would it matter if I did not fit this piece.?
I,lltry upload a photo
Re: Doghouse extension
No, it's a PITA to fit the nut, so you need to install a treaded insert into the case. Then you just use a bolt from the bellhousing side.
Breconbus
Post by Breconbus »
Ok, understood, would it matter if I left the bottom piece off ?
Vents into fresh air as I can see.or I ,m guessing it brings it clear on the cylinder
thanks
Yes, it matters. Do not leave any tinware off. You'll also need to replace the tinware across the back of the engine.
Post by Who.Me? »
Is there something odd about the bell housing in a '65?
My truck has a '67 H-code transaxle and 1600 dual port engine. I can reach the (nearside upper) bolt. Nothing relating to the dog house assembly gets in the way because the bolt goes in from the front, pointing backwards.
It helps to have long arms and a socket extension (and I've read that some clutch arms get in the way), but I've not had a problem. Is your transaxle different?
Who.Me? wrote:
Fri Mar 15, 2019 6:30 pm
My truck has a '67 transaxle and 1600 dual port engine. I can reach the (nearside upper) bolt. Nothing relating to the dog house assembly gets in the way because the bolt goes in from the front, pointing backwards.
His engine WAS a single port, and there was a nut on bolt, not a captive insert. So you'd undo a nut on the LHS like you would on the RHS.
But with a twin port engine that is a pain to do. All twin port cases came with a captive thread insert on the upper LHS mount.
Some earlier gearboxes had curved clutch arms which make the access underneath harder.
Post by Who.Me? »
vwJim wrote:
Fri Mar 15, 2019 6:43 pm
Thanks Jim. I didn't know that the single port engine cases were different (other than the single v dual oil pressure relief bit).
:cheers:
Post by clymoj »
That is why mine is a pain to do then. Learnt something there. I’ve had to ask someone to hold the nut in place while I get under the bus and put the bolt in.
So how does the threaded insert work then? As in what do I buy and how do I fit it? Is it similar to a helicoil?
Post by 8 8US »
clymoj wrote:
Sun Mar 24, 2019 5:22 pm
I’ve got a few of these Jonny, I take them out of my engines to save the hassle of trying to tighten a bolt from underneath :lol:
Let me know when you’re around and I’ll sort you one out.
Pretty basic. You just drill the case and press on an insert. Job done
Post by clymoj »
Lovely, thanks, I’ve got an oil leak to fix and no girlfriend to hold my nuts so anything which makes dropping and refitting the engine solo a bit easier will be very welcome.
Post by 8 8US »
clymoj wrote:
Mon Mar 25, 2019 1:37 am
Give me a call next time you are back.
Post by clymoj »
8 8US wrote:
Mon Mar 25, 2019 7:54 am
Will do, thanks
LoL..no girlfriend around.. LoL
