Help with my bloody locks.
NEILB
Post by NEILB »
Ok, im really buggered.
I have lost my keys to my van. The locks are all on different keys so now might be a good time to sort that as well. For now the van is unlocked and im having to hotwire it to start it. Not ideal! Anyone know where i can get either some new keys cut or some new locks all round!
HELP!!
dottie the bus
Post by dottie the bus »
custom and commercial should be able to help 01372458604
good luck
BBBBBrrrrrrrrrmmmmmmmmmm!!!!!!!!!!!!
Rev Heads!!!!!!!!
http://i48.photobucket.com/albums/f240/ ... G_0524.jpg
dottie the bus
good luck
Rev Heads!!!!!!!!
NEILB
Cheers.
Post by NEILB »
Just spoke to them. They can sort me out. Cheers for the tip.
JimVanDriver
Post by JimVanDriver »
Neil,
As a matter of interest, how much for the full set? Does it include the ignition?
Redthelmem
Re: Help with my bloody locks.
Post by Redthelmem »
I just paid £238 odd quid, I’m an auto locksmith but all mine were on different profiles so I count have re-keyed them if I’d wanted to.
Custom and commercial have been very helpful for my toting, at a cost obviously
DOUGAL
Post by DOUGAL »
Old post dug up?
Get a key cut to match one of the numbers on one of your locks and change all the tumblers on the others to the key.
You will have one key for all and only the cost of a key and a few tumblers. It's a nice and satisfying job to do.
Gertjan
Link to forum post
But if the locks are mixed, the key form that slides into the barrel are different. Early locks EFDVZ codes all the same profile up to end of ice pick handles 64MY then push button 65/66 MYs T code and 67MY L code.
May even have beetle pull handle coded barrels on ice pick handles.
Need to check what the mixed handles are..
https://www.wolfsburgwest.com/wolfsburg ... r_keys.cfm
General interest article on where to find your key code..
https://www.thesamba.com/vw/forum/viewt ... p?t=497431
But when stripping down look for evidence that no one has been in there before you and redifferred the barrel to match a key and not scratched through the marked/ stamped code!
My favourite barell I came across worked fine with any of my T code keys.. a PO/ fiddler had removed all the differs so it could be used... with all VW T profile keys..
