Heater Tube Insulation
Post by 8 8US »
What have people used to insulate the heater tube?
The kit from Schofields is £110 plus ties
https://www.alanhschofield.com/ourparts ... 55900.html
Looking at something like this:-
https://www.toolstation.com/ybs-general ... ion/p16779
Secured with cable ties, any better ideas?
Re: Heater Tube Insulation
Post by clymoj »
I used the latter last time. The R value is pretty low and I can’t say I noticed much difference but I only wrapped it once round I think you might get better results wrapping it multiple times.
Also my bus has stale air heat exchangers which aren’t quite as forceful as later ones.
Post by 8 8US »
Thanks Jonny, as it is 600mm wide I should get it to wrap almost 3 times so will give that a go.
58splitty
Post by 58splitty »
I used this for 4 years, then wrapped it in exhaust wrap later on
https://www.screwfix.com/p/ybs-superqui ... -10m/68120
1958 splitscreen
1969 custom bug (the only bug to have been on the cover of Volksworls and Ultra VW)
1972 roof chopped bug (volksword, street machine, custom car, vw scene)
My invention: www.tapepal.co.uk
New website: www.radialdesign.co.uk
58splitty
Post by 58splitty »
1958 splitscreen
Post by 8 8US »
Thanks for that, will take a look.
DOUGAL
Post by DOUGAL »
Make sure you tape up the ends properly as it will trap water nicely.
Link to forum post
Post by flatbeat »
DOUGAL wrote:
Wed Mar 13, 2019 12:51 pm
That’s one advantage with the stock wrap ala Schofields....it breaths and doesn’t trap water. It’s what I used in the end and it is excellent....imho :wink:
Post by Who.Me? »
If it's for your single cab, I wouldn't get too hung up on the insualting qualities of the wrap. The cab isn't a big area to heat. Mine gets toasty hot quick enough with the original woven fiberglass cloth wrap .
Air leaks from bad window, door, pedal and airbox seals letting cold air in are a bigger issue.
