How do people deal with/fix stripped sump bolt threads?
Hi all,
been watching oil drip while my bus is standing cold and it appears to be coming though alongside two of the six sump bolts (the little 10mm ones with the brass washers). How can I fix this? The bolts are only supposed to be torqued up lightly but on these two bolts in particular it seems that it won't tighten at all so the thread must be worn and I don't want to strip them and make them worse.
Any tips to fix this issue gratefully appreciated!
Thanks,
DD
Thanks,
DD
Member since 1996.
Official SSVC Quizmaster 2014-2018
Member since 1996.
- richandsue
Re: How do people deal with/fix stripped sump bolt threads?
will need a Heli coil or time sert fitting to the stripped threads. prefer time serts myself.
Forgive my ignorance but what's a time sert?
Member since 1996.
Member since 1996.
Dave
Here they are:-
https://eshop.wurth.co.uk/Product-categ ... en/GB/GBP/
I've used them for engine studs.
Can you not try some loctite on it?
Here they are:-
Cheers guys, I'll give it a go!
DD
DD
Member since 1996.
Member since 1996.
i have threaded a bolt from the inside before and used standard nuts from underneath with some sealant in the past
The studs are available from most of the usual suppliers, if it's the stud rather than the case that's suffered with age then it's an easy replacement next time you change the oil.
SSVC Club President
WHS ^^^^^^ This is the easiest fix. Simply tap the case holes to M8 and fit the stepped studs. Stronger than helicoils etc. but don't overtighten them!
1966 SO42 Westy in Velvet Green - on the road at last!
1967 Sundial from Idaho
1971 Westfalia from LA
cheers guys!
Wish me luck lol
DD
Wish me luck lol
DD
Member since 1996.
Member since 1996.
Hiya Dave
With BJ1 on this one, it's how I got around worn threads - part no. N0144781SS from VW Heritage. Don't forget to pre-drill to 6.8mm before tapping out to M8 though!
Good luck mate,
All the best, Grant
Good luck mate,
All the best, Grant
Hi Grant,
cheers for the info!
I bet you don't get this problem in the Zafira lol
See ya
DD
See ya
DD
Member since 1996.
Member since 1996.
No way, that thing goes into a laboratory where its fixed by a robot with a computer!!!
- e m p i
- Location: Essex but I'm nothing like the twats on the telly.
Are the threads on the studs stripped so the nuts won’t do up or are the threads in the block stripped so the stud is pulling from the block? If it’s just the threads on the studs then just pull the stud out with some grips and put a new stud in as that’s better than drilling the block out if you don’t have to.
Sooty wrote: You are a god Lee.
It's not studs Lee, it's just bolts. The bottom of the sump has six holes, not six studs if you know I mean.
When I go to tighten 2 of the six bolts in order to secure the sump plate on, they just spin with a bit of friction, not tighten. And this is where the oil is leaking past those threads.
Pain in the *** anyway!
DD
DD
Member since 1996.
Member since 1996.
