Swing Axle vs IRS Technical Topic
Dipsy
Post by Dipsy »
As there seems to be a lot of interest and discussion on the relatve merits of SA v IRS at the mo, I thought I'd put a sticky up for a while, to try to collect a bunch of expert opinion all in one place. If it goes well, i'd like to make it a regular thing, with different topics all being archived, to help those that come along later asking the questions that get asked time and time again.
Feel free to put your thoughts, both positve and negative for each option, but keep it friendly, and in the interest of posterity, we could even try to stay on topic for a change :wink: 8O :D
Over to you................
Nige
'El <ex> Presidente'
Doc
Post by Doc »
Very good idea.
I'd suggested a Tech FAQ before (http://www.ssvc.ukshells.co.uk/phpbb/vi ... hlight=faq), This seems like a great idea to pull together all the thoughts.
Once enough subjects have been pulled togther it could even be possible to collate the information into a little book may be?
be inspired, visit http://www.paulsrideforlife.co.uk and help raise half a million pounds for Cancer Research
Who Hares wins!
filby
Post by filby »
Have been working on my setup for the last couple of weekends after finally gathering all the bits together, will be chucking a write up into the rides and projects section once all is installed this weekend.... watch this space, will post a link on here when its up on my rides thread!
Couple of sources of info i'd like to put up are the ever superb Bus-Boys type 2 suspension conversions pages found here http://www.bus-boys.com/bbsusp.htm
and also the book How to Modify Volkswagen Bus Suspension, Brakes and Chassis for High Performance By James Hale Image which can be got here:
http://www.amazon.co.uk/exec/obidos/ASI ... 55-7901460
Mark
dubbus56
Post by dubbus56 »
IMHO
I can not tell the difference in ride quality between SA or IRS both great as far as I'm concerned. My pick up is SA'd the 13 window is IRS'd both are quiet and quick. I don't think one holds a major advantage over the other in all honesty.
Hope that helps. :wink:
Ben
1 67 13 and 2332 makes Ben a happy boy!
http://www.skintaracing.com" onclick="window.open(this.href);return false;
http://www.raceshack.co.uk" onclick="window.open(this.href);return false;
SteveW
Post by SteveW »
Isn't straight axling more 'easier' than an IRS conversion? I've seen loads of articles on IRS conversion but nothing much on straight axle conversions!
Steve Image
1965 LHD Devon - 1959 UK RHD Bug
http://www.vintageair.co.uk
http://www.steeringboxscrapers.com
SBS #5 UK Chapter
silversteve
Post by silversteve »
dubbus56 wrote:IMHO
Ben
biggest difference is price, S/A is far cheaper to do, with SA you have to go low (2 splines) over wise you get "positive chamber" and you dont want that!!
IRS keeps the wheels nice and striaght however low you want to go.
In my old bus I had SA, doing my new one now I have IRS'd it so will soon be able to compare.
cheers Steve
dubbus56
Post by dubbus56 »
silversteve wrote:
dubbus56 wrote:IMHO
Ben
cheers Steve
You do have to go lower with SA, that was why I IRS'd the camper, I didn't want to go that low. But most people want to slam them anyway.
Ben
silversteve wrote: biggest difference is price, S/A is far cheaper to do, with SA you have to go low (2 splines) over wise you get "positive chamber" and you dont want that!!
Even in stock strength format, SA has always been cheaper, but with the increasing interest, prices of parts has risen. Noticed how many people have started selling SA kits....?
And in performance strength setup, it is FAR cheaper than IRS.
Mick Annick
Post by Mick Annick »
I'm new to VW's so please pardon my ignorance, but why move away from the original set-up in the first place?
Mick
Sim
Post by Sim »
Mick Annick wrote:I'm new to VW's so please pardon my ignorance, but why move away from the original set-up in the first place?
Mick
both SA and IRS lose the stock reduction boxes on the rear wheels, allowing for better top end speed when used with an engine with more grunt.
IRS also has better suspension geometry for lowered busses as wheels travel more like a conventional swing arm ( i.e camber dosent change as much)
Sim
Mick Annick
Sim
Thanks. I'm planning to keep mine as stock as possible for insurance reasons, so lowering is out but am going for a 1600 lump. A bit more on the cruising speed would be noce for touring - though if I'm stuck with the hub reduction set up is this a non-starter?
Presumably this also limits my gearbox choice?
Mick
You can get 'freeway flyer' gearboxes that work with 'stock' setups. Basically gives you a slightly quicker cruising speed for the same rev's
Bootsy
Post by Bootsy »
vwjim wrote:You can get 'freeway flyer' gearboxes that work with 'stock' setups. Basically gives you a slightly quicker cruising speed for the same rev's
This is the set up I have - coupled to a 1776 is cruises at 60 at about 3300-3400 revs.
Die Deutschen Klassiker - The home of Classic Porsche www.ddk-online.com
ronmidg
Post by ronmidg »
Excellent thread but confess I have no experience of either, I have till next spring to deliver a more reasonable cruising speed though hence my interest. I've just laid a tape measure against the wheel gearbox and it looks like 4 inches between axle and wheel centres, this is about the same as the clearance above the front tyre at its outside edge. If the front track was narrowed a bit there looks to be another inch. I dont know how much of this is suspension travel. So if go for straight axle does it follow that for a level van and neutral camber the front suspension has about an inch of travel at most? I think the ride is already harsh (not a critisism as is what I would expect for a one ton truck), surely x times stiffer is not an option for a family van?
I havnt seen a reference to a freeway flier gearbox before is there more info somewhere?
radish
Post by radish »
Any chance anyone could put up a photo or two of the rear of their vans that have been straight axled. just want to know how low its going to be. obviously wheel n tyre choice will change that but just want to get some idea. cheers
