Hello
Re: Hello
Evening, welcome aboard.
Re: Hello
Hello and Welcome - What are your plans to achieve your want?
Orb
Orb
Re: Hello
Thanks everyone
, dont really know what i want only that i want to run 18 sec and under , 15s sound nice
.Brought the bus in from CA 3years ago MOTed it straight away ,trailered it home put it in the garage and shut the door , so i have finally decided to register it get a quick motor built (by others)and drag race it
So will be asking lots of questions
Re: Hello
Well you ask away, there's always somene on here willing to help.
As a guide you'll need about 120bhp to run a sub 18 and about 175+hp to run in the 15's
I started on the same journey in 2004 and you can read about the different stages here
viewtopic.php?f=8&t=4021
Orb
Orb
Re: Hello
Thanks orb ,
I need an engine builder in the cheshire area do you no of any , going to see one on Sat (think his name is ''Gee'' whitchurch way) but need 2 estimates
I know nothing about drag racing VWs so dont know whats needed
this is wot i think i need
2332 cc FI
Rancho box
Disc Brakes
Skilled engine builder
plenty of dust
Do you think i could get this done for £1500.00
only kidding ,
6-8K what do you think????????
Bri
2332 cc FI
Rancho box
Disc Brakes
plenty of dust
only kidding ,
Bri
Re: Hello
No worries
Ha - I thought we had a dreamer there at £1500!
I've put my best estimates next to your item, none of which include fitting but in short that should get you there but there are always things you forget that add to the cost (extra gearbox mounts, oil cooler and lines, breather system, steering upgrades etc.) - it'll make a big difference if you're able to do some of the fitting work yourself.
Orb
Orb
Brian J wrote:Thanks orb ,
this is wot i think i need - I don't know any engine builders your way but put a separate thread up someone might be able to help
2332 cc FI £6-7k on carbsand an extra £1500-2k if you go FI
Rancho boxCirca £1000
Disc Brakes£7-800
plenty of dust![]()
only kidding ,6-8K what do you think????????
Bri
Re: Hello
hello fella,Brian J wrote:10-12k
I know speed costs big money , I was hoping to get it done for around 8K looks like there is no chance
not to put a downer on the cards
also take into consideration that things break so always have a few quid tucked away to sort it!
have fun..............
Re: Hello
There is a chance, don't be downhearted brother
Those figures are based on building a high spec 2332 making 185-190bhp - that in itself will be £6.5-7.5k dependng on what bits you use - but you don't need to go that route.
There are often turnkey motors for sale much cheaper or kits that would just need building - for example
http://www.volkszone.com/VZi/showthread.php?t=612562
This for example would push you into the 15's - http://www.volkszone.com/VZi/showthread.php?t=609420
I bought my first BWA motor from Paul Utting for £3500, it had already put his bus into the BWA, gave me my first sub 18 run and has since been sold and pushed another bus under 18 secs so it is possible to do it much cheaper and be reliable too.
You don't have to have a box built, some people run them on a stock box but you'll probably start unwinding 3rd and 4th gear if you drive it hard - a new rancho may be a grand but they do come up for sale now and then - for example - http://www.volkszone.com/VZi/showthread.php?t=607776
I bought one that had done 1500 miles for £700 (Cogbox built
Another route to look at which was a really cheap way of dong it a couple of years ago but for obvious reasons has become more expensive is to have an engine built in the states - maybe try dropping a line to Powerhaus in the US and see what your options are http://www.thesamba.com/vw/classifieds/ ... ?id=550433
I know he's very helpful and a friend had a top notch turbo engine built that has pushed his bus into the 14's for what would be the equivalent of approx £7k today - that's Turbo and injection and about 250+bhp
I'm sure they could build a stout motor within your budget.
Orb
Re: Hello
2332 cc FI
Rancho box
Disc Brakes
plenty of dust![]()
Bri
Hi Brian,
If your after an engine and gearbox I would recommend without reserve John Walket in Stoke on Trent, he's not on here but you'll find him on VZI "63 ragtop", he builds and races his own motors and has built countless "bus" engines including mine for one!
Best of luck in what ever you do and see you on the strip
Andy
Re: Hello
thanks guys for the help
I dont want to go the turbo route ,carb or would like FI if it is worth the extra cost
I also do some drag racing at the mo so i know the cost of going fast ,the breakages and the addiction to getting that extra 10th
my main concern is finding the correct company to do the work at the right price,
do you think the engine parts on vzi would suit my needs? box has sold
would rather pay a little extra now to get a 15 than more money later
Re: Hello
thanks for that will get in touch with himpye1man wrote:Brian J wrote:Thanks orb ,
2332 cc FI
Rancho box
Disc Brakes
plenty of dust![]()
Bri
Hi Brian,
Andy
is he the guy with the yellow bug ?????
