'67 Sundial... My first! Alfie, with motor video ;)
Re: '67 Sundial... My first! Now known as Alfie ;) Updated!
Looking Good Paul.
Re: '67 Sundial... My first! Now known as Alfie, with engine
That looks excessively Nice...
NICE..
Looks really NICE
NICE..
Looks really NICE
Very sexy
If you're going to dive in then make sure it's the deep end ! SIMPLES
Thanks guys.
Before rebuild, engine bay was media blasted, then sprayed. No rot found in there
Rear valence to spray, whilst the new loom is fitted, fuel lines and cooler, etc...
Soon, very soon... Back on the road
Not near the spec sheets at the moment.
Will post more spec up in a couple of days
Love the engine, would love something similar for mine.
Rick
Rick
Clutch Housing Integral
Clutch Operating Shaft HD 16mm fully welded suitable for late clutch release bearing
Main Casing Aluminium HD Rhino Casing
Side Covers HD Aluminium both sides
Gear Carrier BEARS reconditioned stock casting, aluminium sleeved for late style integral thrust front mainshaft bearing
Shift Housing Aluminium Split bus style with stock HD shift rod
Differential Quaife ATB LSD with 33 spline, stock 15 mm drive flange seals
Drive Flanges Chromoly 113 to 091 conversion flange mates to stock 091 bus CV joints
Mainshaft Weddle Hybrid splined for HD 3-4 hub
Mainshaft Idler Gears Matched to mainshaft fitted with VAG synchros
1st/2nd Slider and Hub New VAG 002 slider stock hub
3rd/4th Gear Sets Weddle Racing with splined floating dog rings, with VAG synchros
3rd/4th Slider and Hub Weddle Racing HD hub with new 091 VAG slider
Ring and Pinion new US Gear splined 3rd and 4th gears
Pinion Bearing Retainer Chromoly HD 4 bolt
Shift Forks new VAG steel
Reverse Gear Assembly Weddle Racing slotted
Bearings new FAG and VAG
Re: '67 Sundial... My first! Alfie is alive engine video ;)
The money shot!...
https://www.facebook.com/video.php?v=62 ... 15&fref=nf
Just can't wait to get home and start piling on the miles
