Rusty, our 1962 11 window bus, resto now in year two……er, three...
rusty1962
Re: Rusty, our 1962 11 window bus, resto now in year two……er, three...
Post by rusty1962 » Mon Mar 19, 2018 6:35 pm
Evening all.
The new slave cylinder uses a 7/16" unf fitting in one of the holes and the other's a 3/8". I've had to order the larger one off the 'net as they're not readily available in my neck of the woods.
New brake pipes made and just about ready to install. Just awaiting the union...a bit of finessing to get the lines all straight and the job's a good'n
Laters
visit my webshop
Halso Aircooled VW Oil
Bren Ralls
Post by Bren Ralls » Mon Mar 19, 2018 7:54 pm
Just a little tinker 😉
rusty1962
Post by rusty1962 » Mon Mar 19, 2018 8:11 pm
I'll be giving him a wash soon 😲
visit my webshop
rusty1962
Post by rusty1962 » Tue Mar 20, 2018 8:11 am
Aren't I ? :)
visit my webshop
Post by type21f » Tue Mar 20, 2018 8:13 am
rusty1962 wrote:
Just a little tinker Image
Aren't I ? :)
yes...
rusty1962
Post by rusty1962 » Tue Mar 20, 2018 8:17 am
Aren't I ? :)
yes...
You're still about then?
Have you booked VF yet?
visit my webshop
Post by type21f » Tue Mar 20, 2018 8:19 pm
Sent PM...
rusty1962
Post by rusty1962 » Sat Mar 24, 2018 8:57 pm
:bounce: Evening all :bounce:
I finally finished off the handbrake job today, getting the brakes bled. It works very well. The cables tension applying the handbrake pads and then with the last two clicks the hydraulic circuit comes in. Should make hill starts with the Puck on a bit easier 😁
The rest of the day was spent modifying a belly pan to fit around the Red 9 steering arm.....
Just got to Gravitex and then paint. Should be fitted for VF :cheers:
That's all
visit my webshop
Post by type21f » Sat Mar 24, 2018 9:07 pm
Good
rusty1962
Post by rusty1962 » Sat Mar 24, 2018 9:38 pm
Not sure what's happening with the direct upload photos..... :?:
visit my webshop
Starsky2727
Post by Starsky2727 » Sun Mar 25, 2018 2:40 am
rusty1962 wrote:Not sure what's happening with the direct upload photos..... : ? :
I can see pics fine
Post by type21f » Sun Mar 25, 2018 6:48 am
yes OK now!
rusty1962
Post by rusty1962 » Sun Mar 25, 2018 8:59 am
I can see pics fine
I've only uploaded three but I can see each one three times! I've reported to Miles :?:
visit my webshop
rusty1962
Post by rusty1962 » Wed Apr 11, 2018 5:13 pm
I collected the modified belly pan from the painter today. Just got to get some stainless penny washers now and then I'll fit it :D
visit my webshop
rusty1962
Post by rusty1962 » Sat Apr 14, 2018 9:50 am
:bounce: Morning all :bounce:
So.....a quick job today, prior to starting to use the bus for some long journeys, and one that's sure to send a few if you scooting off to Rymans........😂
Wind whistle....from the quarter lights.... :evil: :cheers:
This is what I did.....
and after a bit of cutting with a sharp knife....
:D SORTED :D No whistle when quarter light closed :cheers:
Would be better if A3 length was available so no joint required. I'll check that.....
That's all folks
visit my webshop
