Restoration 64 split screen
mickg
Post by mickg » Wed Jan 30, 2013 7:25 pm
Hi all
can anyone help I am doing a restoration on a 64 split screen and I can't work out how to post pictures I have got an account with photo bucket and uploaded some pictures to it in a library but i'm stuck now I must be getting old or is it not as easy as you would think ?
Thanks for any help Mick.
Marvelwear
mods could you move this thread please :-)
Post by Marvelwear » Wed Jan 30, 2013 7:56 pm
is selected you copy the direct link from your photo bucket into the gap between the img brackets. Then your picture will load:-)
Aspro
Re: Help with posting pictures from photo bucket
Post by Aspro » Wed Jan 30, 2013 8:06 pm
Or alternatively. Click on the image in photobucket. On the right of the screen you will notice a box titled "Image Links". Copy the link entitled IMG code. It's the 4th one in the list. Past that directly to your post. Easy
mickg
Re: Full restoration on a 64 split screen
Post by mickg » Wed Jan 30, 2013 8:19 pm
Ok thanks I will try that so I have to copy every picture
mickg
Post by mickg » Wed Jan 30, 2013 8:21 pm
A bit like this then Image
cheers
Marvelwear
Post by Marvelwear » Wed Jan 30, 2013 8:37 pm
Yay, well done fella:-) nice van:-)
mickg
Post by mickg » Wed Jan 30, 2013 8:55 pm
Hi is there any rules about posting pictures I am doing a full restoration and there are many pics
Cheers Mick.
nige1171
Post by nige1171 » Wed Jan 30, 2013 9:06 pm
mickg wrote:Hi is there any rules about posting pictures I am doing a full restoration and there are many pics
Cheers Mick.
Yes, lots and often :cheers:
My build thread...
viewtopic.php?f=8&t=69457
mickg
Post by mickg » Wed Jan 30, 2013 9:41 pm
Its in quite good condition Image
Of to work for the start
At this point I have had the red 9 suspension on order for five weeks the new engine has been stripped and painted Image
Stripped and ready for a quick blasting Image
Blasting underside done Image
Oops lots of filler Image
Got to go new one on order Image
Meanwhile I need more windows Image
I still need more windows Image
Back out for a bit more blasting Image
A few repairs and a good coat of zinga and I can forget about this for a few years Image
A new face for splitty Image
Yes more windows Image
Sorting out the samba windows Image
This side was also full of filler so of with it Image
A quick coat of etch primer while we sort some fab out it took an age to get all the paint of I don't want it going rusty Image
I have put in some lockers for tools and spares Image
Finally getting some product on after the filler work we have put two coats of spray filler Image
Guide coated Image
After blocking dow the spray filler we have put three coats of high build primer on we will leave the roof now for two weeks to settle Image
Time for me to do some more repairs there is not much to do just one out rigger a jacking point and both centre supports Image
I did have to make a bit of wing as well Image
The odd repair here and there Image
Even though we fitted a new front panel we still had to give it a small skim of filler just to get it nice Image
Here we are getting all the panels fitting just right Image
After the repairs we gave the van two coats of spray filler Image
Panels look good all the gaps are now spot on Image
We guide coated the spray filler and blocked the van with the panels on so we could block through after it was all rubbed down we did it again Image
Then three coats of high build primer Image
We will leave it now for as long as we can to let the primer settle Image
It will give me time to sort out the underneath Image
The heater tube was shot so I made a new one I am fitting a gas heater so I have re routed the tube a bit Image
As you can see here Image
I have fitted the hook up box here Image
Belly locker all seam sealed and etch primed I will be using the bus a lot so I want to make sure its well sealed up Image
This is a two pack surfacer the underneath looks in good order Image
I fitted the gauges here but they are on a strange angle Image
So I made this Image
Can't wait to block this down Image
Underneath in stone guard 15 tins of it Image
Well I hope you like it so far I will post more pick next week
Cheers Mick.
nige1171
Post by nige1171 » Wed Jan 30, 2013 10:00 pm
Crikey! 8O someone's been a busy boy :wink:
It looked in good nick before you ripped it apart! What colors and look etc are you aiming for?
Lowered or stock height? Wheels? Etc
Btw, if you want to edit your main thread title now you're rockin on with the resto pics just go to your first post and hit the edit button and change it there. More ppl will then be attracted to look :D
My build thread...
mickg
Post by mickg » Wed Jan 30, 2013 10:27 pm
Hi I am looking for a slightly lowered look I have fitted red 9 design suspension for a good ride and it uses a steering rack so I can drive it in a straight line I have also fitted Jag seats for comfort on the long journeys I know I will get some stick for that but hay ho, it is going red and white but with a twist thanks for the heads up on the title I will sort it
Cheers Mick.
mickg
Re: Restoration 64 split screen
Post by mickg » Thu Jan 31, 2013 6:58 pm
So now we have the underneath base coated and clear coated we have painted a bit of red hereImage
And got the new suspension on Image
This is the reason for the red paint Image
New wheels as well Image
The inside all ready for some colour Image
Inside done Image
Marvelwear
Post by Marvelwear » Thu Jan 31, 2013 7:14 pm
Well that makes a refreshing change, like the underfloor chest idea, after all the originals used these areas for water tanks etc and your not the first or last to turn your bus into a greenhouse, nice job, your not doing the rear windows? 21 looks nice ..thats a very bling interior. I likey:-)keep it up
mickg
Post by mickg » Thu Jan 31, 2013 7:45 pm
Cheers for that yes I had not thought about the greenhouse thing but it's a bit late to worry about that now, we are going for a modern look inside with a few comforts with a classic look outside
we do want the bus to be good on the road that is why I went for the red 9 suspension good brakes and steering I will keep the pictures coming
Post by maddison » Thu Jan 31, 2013 7:56 pm
lovely - its gonna be a cracka !!
