Go on then, here's my 66.
Re: Go on then, here's my 66.
Hi Kev.
Glad to hear your making progress.Looking forward to see the van finished.
Cheers Lee.
Cheers Lee.
- split bus kev
Hi Lee!
How you doing?? How's yours coming along?
- split bus kev
Clean jobs last night.
Lots of little things, but every little step is good.
Hi Kev.
My vans still in mates paint shop,painted inside,underside and engine bay. He says it going to be next month before he does outer,so no vic farm/stanford hall for me. On the plus side i've fitted so far, wiring/suspension/brake pipes/gearbox.Next job cables pedals/finish brakes and tank.
Are you still on track for stanford hall ?
Cheers Lee.
Cheers Lee.
- split bus kev
Sounds like fairly solid progress, Lee.
Ok, first day of the big bus week down.
Shift rod installed. Wasn't expecting that to be as much of a pain as it was!! New bushes on, had to drop the beam slightly to get it in(?) Hooked it up to the hockey stick, couldn't fix it to the new front rod that arrived this morning as I was sent the rear coupling instead of the front one. Doesn't turn quite as easily as I'd expected, but we'll see...
So, front beam back on, front shocks mounted, washer bottle fitted with new rubber cap
Clutch cable ran at long last!! Bracket made and fitted for a return spring on the accelerator pedal mechanism as the return is just shocking.
Aand breathe.....
New tank cleaned and painted and sender and new outlet fitted. Then went to make sure the tank strapps were ok and realised there is the end of a bolt sheared off in the body on one side. So had to drill that out.
So, combine that with the usual hunting for stuff you've had lying round for years, but that disappears as soon as you need it, breaking drill bits and the wrong stuff in the post and that's day 1 gone.
Tank in tomorrow. Hope those gears are ok, then it's time to throw the engine in.
Oh, and I haven't booked the mot yet for fear of jinxing it...
Aand breathe.....
I'm classing that as just about ready to hit the road then Kev. Get that MOT booked!
- split bus kev
Knackered....
Engine is in after clearancing the bellhousing. I thought it was a 12V box - still do, but it wouldn't go in without the flywheel catching the thicker sections at the top of the box.
I think it needs to come out again though as the thing is solid now and I can't turn the engine by the crank pulley any more. more clearancing needed it seems.
Also, the back end needs to come apart again as it definitely sits too low with the engine in, the spring plate stops need ground down too I reckon. So, perhaps a 1 inner spline rise. Pain in the arse as that means disconnecting the handbrake cables to get the axles off the spring plates. That back end has been apart and together so many times..... I might wait until I see what it does with the rear shocks on.
Should get some goodies in the post today anyway.
Oh and I think I have gears. Seems a little crunchy and massively more close together with the Hurst shifter on.
I need to sort my electrics. There are loose wires all over the place as I haven't looked at it since before it went to the trimmers. Now when I connect the battery, it tries to turn the engine, without the key in.....hmm. Didn't do that last week.
Oh well, here goes..... back in the garage.
Oh, and another thing. Does anyone know where to get longer panel clips? With 3mm ply door cards and vinyl on, the ones I got from Justaircooled http://www.justaircooled.co.uk/door-car ... clips.html aren't long enough.
- split bus kev
Well, project Stanford Hall is a little behind schedule, but still hopefully just possible.
After a week of going up and down constantly on axle stands. I discovered that my gearbox needed a hell of a lot of clearancing to get the engine in, but it's in and spins free.
Sad to say it sat a little too low at the back with the engine in, so I whipped it all apart again and got another inch of ride height. I suspect it will be a little impractical still on campsites, but we'll see.
Not had the engine running yet as I went to hook the electrics up on sunday and realised I didn't have an oil pressure sensor and the fuel hose clips that SSVC spares had sent along with the hose were too small. I was dead chuffed to sort out a couple or really annoying electrical gremlins today. The indicators went solid with the ignition on and I had no speedo pod warning lights. Turned out I'd wired a live to the ground terminal on the speedo. All sorted now.
My boss was asking about it today and suggested that I take tomorrow off to try and get it running, so that's the plan.
Still no MOT booked, but I'll do that tomorrow.....
So, anyway - here's a couple of in progress shots as it's all about the pics really.
All that kept me going some days
If I do make it to Vic Farm, please come say hello....
Last edited by split bus kev on Mon Mar 26, 2012 12:22 pm, edited 2 times in total.
Won't see you at Vic, as i'm not going, but best of look. Looking amazing!!!!
'NEVER SACRIFICE WHO YOU ARE JUST BECAUSE SOMEONE HAS A PROBLEM WITH IT'
SPLITLESS...
The last 5 years! viewtopic.php?f=8&t=44037
SPLITLESS...
- split bus kev
Bus not starting.... nothing coming out of the dizzy.
MoT booked for Saturday morning... GULP!
Keep at it mate. I'm off tomorrow if you need a hand with the wiringsplit bus kev wrote:Bus not starting.... nothing coming out of the dizzy.
(Kev from across the road)
[quote="split bus kev"]
[quote]
Ah - so this is why the resto is takin so long - sunny days and too many of these!
[quote]
65 mdl double door walk through EZ Camper
Resto thread - viewtopic.php?f=8&t=51283
http://www.haywood-classic-custom.co.uk/
Bug gone to Switzerland!
- split bus kev
Wow! What you doing on here?!
You thinking of selling that T4?
Having a go at the engine later, so listen out for the explosion.
- split bus kev
ollieb7 wrote: Ah - so this is why the resto is takin so long - sunny days and too many of these!![]()
- split bus kev
Another disaster!
The shaft on my distributor is bent!
Need a new Bosch 009 like now! And it's royal wedding day tomorrow!
