59 11 window project
splitty_ash
Re: 59 11 window project
Post by splitty_ash » Tue May 12, 2015 7:30 am
That's the registration documents all ready to post this morning, exciting and nervous times, sending special delivery so will be there by 1pm tomorrow ImageImage
treat everydays as if its ur last coz one day it will!!!
www.gyvw.org
splitty_ash
Post by splitty_ash » Fri Jul 31, 2015 9:52 am
PUGSLY now has a reg plate, all up and running as well just needs some small jobs to finish, should be ready for skegvages
The attachment ImageUploadedByTapatalk1438336291.330347.jpg is no longer available
www.gyvw.org
splitty_ash
The attachment ImageUploadedByTapatalk1438336369.837253.jpg is no longer available
www.gyvw.org
dustysplit
Post by dustysplit » Fri Jul 31, 2015 11:57 am
Bus looks fantastic bud, so glad you didn't sell it! Colour is awesome :cheers:
splitty_ash
Post by splitty_ash » Fri Jul 31, 2015 12:15 pm
dustysplit wrote:Bus looks fantastic bud, so glad you didn't sell it! Colour is awesome :cheers:
Cheers bud, I'm pleased to, was just having one of those weeks where I had lost the will to finish it even tho it's so close, roll on skegvegas for its first camp out :-)
www.gyvw.org
splitty_ash
Post by splitty_ash » Fri Aug 21, 2015 7:20 am
https://vimeo.com/136903301first test drive after the 4yr resto, engine to come out again tho as clutch sounds f**cked :-(
www.gyvw.org
splitty_ash
Post by splitty_ash » Fri Aug 21, 2015 7:53 am
Anyone got any ideas of what it could be, 200mm flywheel/clutch, clutch is fully adjusted up and even tried to gain more by adding a 10mm spacer on the adjuster but still sounds the same, it will also not allow me to change gear while the engines running, once it's turned off I can select gears, have to start it in the gear you won't and slowly creep away
Any advice would be great
www.gyvw.org
Hongkongphooey
Post by Hongkongphooey » Fri Aug 21, 2015 10:20 am
So close... van looks great :D .
Not 100% sure on the clutch, have you got the right cable in there? if there is no thread on the cable left to adjust it could be too long? first time I did mine I fully adjusted the cable and it looked tight, but still needed to adjust it up more to get gears... think you should have this length... http://www.machine7.com/product.php?xProd=2845&xSec=368
Maybe worth pulling the cable and measuring before you pull the engine as it will be a lot quicker :)
I am guessing you have the bowden/conduit tube on the side of the gearbox? but does it have enough 'droop' in it? think it should be about 1" from an imaginary straight line. I am guessing you got the clutch with the engine? could not see details when I went back through the thread, but was the release bearing ok?
Hope you get it fixed soon.
'60 RHD Devon
splitty_ash
Post by splitty_ash » Thu Oct 01, 2015 9:53 pm
Had to fit a new clutch and all is good now, just need some adjustments as now 3rd/4th gear but runs perfect in the rest, had a run up the road init and loved it
www.gyvw.org
Biglozzer
Post by Biglozzer » Sun Oct 11, 2015 8:49 am
I hope you've entered Ssvc van of the month for Oct? This is definitely a before and after contender. Looks amazing mate. Well done.
1959 OG paint Mango bus with curved Devon interior. http://m.youtube.com/watch?v=bEVPMkZUEes
1955 Dove Blue micro bus
1959 Canadian Mango micro bus
1970 Porsche 914
2004 Harley Davidson Road King
1959 MGA Roadster
splitty_ash
Post by splitty_ash » Sun Oct 11, 2015 9:08 am
I
Biglozzer wrote:I hope you've entered Ssvc van of the month for Oct? This is definitely a before and after contender. Looks amazing mate. Well done.
I haven't but I will get onit today, cheers mate :-)
www.gyvw.org
splitty_ash
Post by splitty_ash » Thu Nov 03, 2016 8:24 am
Alittle update folks, bus is running fab and nearly time to put it away for winter
Plans are for a steering box lift, dual circuit brake setup and sort the oil leak from the engine
Here's a couple of Randal's from this years show season
Be sure to pic up a volksworld magazine soon as we've a full feature going in Image
www.gyvw.org
splitty_ash
Post by splitty_ash » Fri Feb 03, 2017 10:36 am
Finally got the bus booked in for a steering box lift, using the hayburner kit (excellent quality bit of kit)
Also finally fitting a steering damper, let's hope that help with the pulling all over the place and make a better more enjoyable ride
Also decided it needed a rear bumper so got myself a fibre glass one as ALOT cheaper :D
www.gyvw.org
