empsters ongoing ride.......Time for a bit of a trim
Re: empsters ongoing ride....Red9Design all fitted up....
Post by clymoj » Tue May 19, 2015 9:27 pm
Looking forward to the full update Lee.
Post by e m p i » Thu May 21, 2015 9:34 pm
Soooooo, the drive home..........
Got to the end of the road where the Red9 workshop is and you have to do a sort of dog-leg left / right and as I didn't expect it to turn quite as quick as it did I kerbed it :lol:
It felt a bit weird at first as the steering didn't centre itself without a bit of help like I'm used to but once you'd driven it a while you got used to it and didn't notice it. The roads were a bit sh!t and previously I'd be feeling every bump and pot hole and the suspension would have been banging and clanging as the ball joints bottomed out and due to the harsh ride I'd have been bouncing all over the seat.
Well there was none of that at all :cheers: it just rode over the bumps like a normal car. I found myself tensing up as I hit the bumps expecting the jolt I'd come accustomed to but it never came.
Got into the M-way for the long drive home and thought I'd give it some to see how it rode the long dips that you get on the motorway and it was absolutely fine. Again no banging or bottoming out. I even managed to pour a cup of coffee from my trusty flask into a normal cup and drink it without chucking it all over me or the bus.
The first thing I noticed once I got it up to speed was that my front wheels need balancing. Due to the play in the standard box I didn't really feel this but with the new system it was very apparent.
I also found that I could feel every track in the road that lorries leave as you could feel the twitch in the steering as it hit them. Bear in mind I run 155/65X14 tyres which are quite skinny so that didn't help (more of the tyres later).
The plan was to drive home in two hits as I'd not had much sleep and I was absolutely knackered but it just felt so easy to drive compared to before that I eventually just did it in one hit sat in the outside lane at 70 mph all the way. Most of the time I could just sit with one hand on the wheel with no problems at all, except the occasional twitch when the tyres found a groove in the road surface.
Got home with no issues at all but was so shattered that I just put it in the garage and chilled out and went to bed.
Cheers, Lee.
Post by e m p i » Thu May 21, 2015 9:53 pm
Some porn for the picture perverts :lol:
And no taking the p**s out of my chav-tastic red brakes :roll: They were already done like that when I bought the bus and I always meant to paint them black but I grew to like them so I've kept them :cheers:
The bevel box that the bottom of the column goes into. It's fitted with a small guard at the front that you can see but I might look to build something a bit more substantial that comes a bit further back to protect the UJ and the rod.
Top mounting for the coil-over and the top wishbone. The castor angle is set by spacing the mounting of the wishbone accordingly. The various holes are so that you can mount the entire unit higher or lower then you use the coil-over to fine tune the ride height.
When I took a closer look when I got a chance I decided that it seemed to be sitting slightly higher than I wanted so you have two choices. You can move the whole unit by un bolting it and changing the the holes you bolt it back up with. This gives an inch difference per set of holes, or you can wind it up/down on the coil overs.
Each way had it's benefits and drawbacks. It's easier to use the coil overs as these are set about half way so you get about an inch and a half adjustment either way but it will affect the tracking as you're moving the steering arms relative to the wishbones but it's easy to do. By moving the whole unit on the mounting bolts the alignment doesn't change at all because you've not actually altered anything you have just sited the entire unit higher on the chassis rails. To me that looked like a bit of a nightmare of having to support the unit on jacks and the weight of the bus on more jacks and lowering it all into place to line up the mounting holes.
Post by vwJim » Thu May 21, 2015 9:55 pm
Get the caster set correctly and it should self center.
Post by e m p i » Thu May 21, 2015 10:04 pm
Here you can see the adjustment on the bottom of the coil-over.
I opted to use this to adjust the ride height as I just thought it looked like it was sitting about and inch or so too high and so the gap between the top,of the tyre and the arch was too much and looked a bit odd.
Before I had a chance to play about with the height I took it for an MOT which it passed with flying colours :cheers: :cheers: :cheers:
The bloke just said to keep an eye on the inner edge of the front tyres as they were wearing. I'd already noticed this before but didn't think they were that bad so made a note to keep an eye on them.
I'd already decided to put something a bit wider on as when driving it I was still finding it a bit twitchy which I put down to the tyres being so narrow (155 width remember).
Took it to Stanford Hall and had a lovely day out with a fantastic drive there and back :cheers: It made such a change not to be looking for every dpi and pot hole and gritting my teeth waiting for the bang as everything bottomed out.
Made a note though that I needed to sort out the tyres as it was still catching the grooves in the road (more of that later).
Post by e m p i » Thu May 21, 2015 10:05 pm
vwJim wrote:Get the caster set correctly and it should self center.
:lol: you're ahead of me there, I can't type that quick :lol:
Just glad someone's reading it all to be honest :lol: :lol:
Post by e m p i » Thu May 21, 2015 10:13 pm
Here's a shot of me and little Empi on a day out to the seaside 8) 8)
It must be a smooth ride as he slept most of the way there and all of the way back :cheers:
Clear blue sky, waves lapping at the shore, ice cream along the promenade........what's not to like 8)
Cheers, Lee.
Ps. More about those tyres to follow but I'm off to bed now.
Crooky
Post by Crooky » Thu May 21, 2015 10:17 pm
that looks like some serious kit mate and the bus looks mean 8) - I'm going to have good look to get my head around what's what but nice one.
Nobody makes me bleed my own blood!
1957 Dove Blue Kombi from Montana
MarkFer
Post by MarkFer » Fri May 22, 2015 8:36 am
Are all those allen-head bolts rusty? How long has it been on?
Post by e m p i » Fri May 22, 2015 9:08 am
MarkFer wrote:Are all those allen-head bolts rusty? How long has it been on?
Yes it's almost like a surface coating that's appeared as they look like they have some sort of black coating on them. I'm looking into it but this was pointed out
paul_f wrote:It often is quite hard to get fine thread 12.9 cap heads 12.9 in anything but chemi-black
So I wonder if it's something to do with them having to be a certain tensile strength meaning they can't be coated with zinc etc. it's only been on a couple of weeks and done about 1000 miles (all in the rain :roll: ). I'm going to look at other options for the bolts, even if it means having them coated myself.
Cheers, Lee.
Post by e m p i » Fri May 22, 2015 9:13 am
Unfortunately I don't have a before picture, but while I was sodding about I noticed that my front bench seat was looking a little grubby so I attacked a small section with a nail brush and some washing up liquid. Big mistake :lol: One nice clean patch which stuck out like a sore thumb against the grubby looking rest :roll:
So an hour and a half later I had it all done and a bowl or rather disgusting looking water which Made me cringe that I'd let it get so filthy :oops:
Here's the "after" picture
Mental note made to clean it a bit more often as once little Empi gets a bit older it's bound to get half eaten sweets and drinks spliced all over it :lol: :lol:
Cheers, Lee.
Edit to add........ yes, I do have a lot of junk on the top of the dash :lol:
andy f
Post by andy f » Fri May 22, 2015 9:45 am
Whoa, that is some interior you got going on there, luv it 8)
Post by e m p i » Sun May 24, 2015 8:20 pm
andy f wrote:Whoa, that is some interior you got going on there, luv it 8)
:lol: cheers mate, it's taken about 12 years to collect all that junk to hang and stick there :lol:
Post by e m p i » Sun May 24, 2015 8:35 pm
So after driving it about for a few days I thought I'd have a closer look a the ride height as there was definitely a bit of a big gap between the top of the tyre and the arch. It's probably just me being picky but I didn't really like the look of it. Also the tyres.........when I'd been driving it as opposed to not feeling anything through the steering previously I could now feel everything and it certainly felt like the front tyres were tracking a bit and possibly jumping a bit as well, possibly because they were too narrow or possibly because the alignment wasn't spot on. Not sure but thought I'd have a looksie.....
I found that the inside edge of the front tyres had scrubbed almost down to the canvas 8O .
When I looked at it sat on the drive I couldn't make my mind up if the camber was way out or not. Reason is that I think my drive sits a bit on the wonk, the bumpers definitely sits on the wonk and I've most certainly got wonkey eyesight :lol:
Anyhow, whilst I was contemplating ride height and tyre sizes I thought I'd pull the front wheels off and give them a bit of a clean up. On the inside. So I set too with the intention of cleaning off (at least) twelve years of accumulated brake dust, road salt, road gunk, dead hedgehogs and whatever else had managed to congeal on the inside of the rims and set rock hard. And I really do mean rock hard.
First thing was to soak it a bit to try to soften it up. Here's what I started with....
Extreeeeeeeeeeeeme close-up
What a filthy stinking disgusting mess 8O 8O
Post by e m p i » Sun May 24, 2015 8:55 pm
I also spent about a week playing about with online tyre size calculators working out how much extra or less I would gain in sidewall height depending on what width I went for and how it would look if I dropped the front by an inch or so and what the difference would be in rolling circumference. I ended up with a bit of A3 sized paper with rather a lot of pencil lines and measurements on it that I could use to compare widths and sidewalls with on the half dozen sizes is narrowed my choice down to.
I settled on 175/60X14 and phoned my tyre shop of choice (chosen because they also have a 4wheel laser tracker and can do the camber as well) and told the man what I wanted. To which he said " that's a bit of an odd size, what's that going on" :lol:
I was also getting a tyre sorted as a spare for my bro in law but he runs 15" rims with different size tyres front and rear but has a 14" spare so I worked out what size would be best for him as well. Texted him the size and explained how I came to that conclusion and said it all makes sense if you understand how to decipher the sizes. He texted back that it might so if you're Stephen Hawkins :lol:
Tyres duly ordered and arrangements made to take the bus in to get two new fronts plus me using their ramp for half and hour to play about with the ride height and then them to set the tracking and the camber and check the castor.
If I had decided to just remove and re-mount the entire Red9 unit then the tracking shouldn't change but the minute you start using the adjustment on the coil overs it alters the toe in/out as you're changing the angle of the steering arms. I opted to adjust the height using the coil overs as I only wanted to drop it a small amount and to be perfectly honest didn't fancy un bolting the whole lot. Also I think by altering the ride height by the coil overs it might also alter the camber as the angles of the top and bottom wishbones will change in relation to each other unless they are of equal length ? But I could be wrong on that....
Cheers, Lee.
Ps the wheels cleaned up a treat. Eventually :lol: pics to follow.
