AWD 964/911 Bus
john&hannah
Re: AWD 964/911 Bus
Post by john&hannah »
Offered up the doors today and at first it all seamed ok -
ImageDoggy Doors by Duke of Boots1966, on Flickr
....but then some issues started to raise their heads. I am sure this should close further....
this seems ok
ah rats, a good inch at the bottom which makes me think the door bottom is warped which given the crap welding and repairs that are down there is a distinct possibility.
and the off-side is not much better.
ImageDouble door trouble by Duke of Boots1966, on Flickr
Looked online but CandC have stopped doing the bottom section frame repair and their correct fit replacement door is for 55-60 so has the wrong handle pressing. hmmmmmm :roll: :roll:
john&hannah
Re: AWD 964/911 Bus
Nothing a bit of filler can't sort out.....
ImageAll straight and level by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Cut the dash out of the bus today and got to the heater tubes. Hmmm some work required.
ImageDash it by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
Started tackling the dash repairs today. could be a long job.
ImageDash 2 by Duke of Boots1966, on Flickr
Not much to weld to so out it comes
Hole gone
ImageFast 3 by Duke of Boots1966, on Flickr
john&hannah
Re: AWD 964/911 Bus
There is something not quite right with my parcel shelf, answers on a postcard.........
ImageMishmash by Duke of Boots1966, on Flickr
john&hannah
Purists look away now!
I resigned myself to resurrecting my worm ridden air box but purists should look away now!
ImageCheese by Duke of Boots1966, on Flickr
ImagePurists look away now! by Duke of Boots1966, on Flickr
dom_k
Re: AWD 964/911 Bus
Post by dom_k »
Loving the previous parcel shelf ‘repair’ - the pressings in the plate nearly match the originals :lol:
john&hannah
Re: AWD 964/911 Bus
:compress: The left hand side is fat lip pressing and the right hand side is thin lip pressing so it can be used on all years of bus :lol:
john&hannah
Less ventilation more metal
Spent the day repairing the sidewall of my cab air box today. Tough finding any sort of metal to weld to and add the mig on such a low amperage it felt like soldering :cyclopsani:
Before -
ImageLess ventilation more metal by Duke of Boots1966, on Flickr
After -
ImageMore metal by Duke of Boots1966, on Flickr
john&hannah
Left and Right stuff
Got the steering box and associated U/J's in today and fabricated the morning brackets.
ImageLeft and right stuff by Duke of Boots1966, on Flickr
Looking back towards the Porsche 964 steering rack
Steering box on the right bidding behind its mounting bracket
If you ever have to fit a top bearing then the order is
bearing, split washer, spring and not like this!
john&hannah
Off to get sprayed
The chassis having its final prep before heading of for shot blasting and weld through primer. Hopefully the last time it is upside down.
ImageOn its head by Duke of Boots1966, on Flickr
john&hannah
AWD Porsche 911 Splitscreen
Today was all about fixing the cab door locking mechanism with a clothes peg.....
Original looking system with return spring for the latch intact -
ImageDoors and Stuff by Duke of Boots1966, on Flickr
The clothes pegs who may provide the answer -
The cut down clothes peg spring -
and in situ plus a repair to the retaining rivet -
john&hannah
Re: AWD 964/911 Bus
Cargo door fixing day. Trying to make 2 good doors out of 4.
Off with the old -
On with the new skin -
And a repair to the bottom frame -
Not so 'perfect fit' repair panels (again!) -
Cut out the original window aperture -
Pulling out a bashed in bump stop with a metal bar, 2 nuts and a bolt -
Donor window tacked in place -
john&hannah
Re: AWD 964/911 Bus
The chassis waiting for its primer having been shot blasted
ImageChassis at spray shop by Duke of Boots1966, on Flickr
john&hannah
Cab door stops
So I was mildly surprised to find that the correct fit A pillar does not have the door stop fitted into it so there is no other option than to cut a new post and retro fit the old piece. Given that when they came from the factory the door stay was weld into the A frame and sandwiched between the 2 parts then it would have made sense to do this with repro parts but rant over.
Sooooooooooo.....
Cutting a new post :evil:
ImagePerfect (ish) fit by Duke of Boots1966, on Flickr
Fitting the old door stay
Cutting the inside of the A frame and welding in the reinforcing leg. Originally it was sandwiched between the 2 parts that make up the A frame but I bent the leg so it would pop out the cut i made and could be butt welded.
and making good -
And fitting the door to check alignment (doors don't come with the door stay hole either :bounce:
