1956 RHD Wolfsburg Kombi Resto. AKA 'Bucket'
John TC
Re: 1956 RHD Wolfsburg Kombi Resto.
Post by John TC » Tue Dec 10, 2013 7:47 pm
grant wrote:Cool mate a right little girl. Ur bus is looking awesome bet you have learnt some since we first met!!!!
Kids are great arnt they :D
Its been a real interesting journey so far Grant and have learnt a lot
------------------------------1956 RHD Kombi.------------------------------
viewtopic.php?f=8&t=82512
---------------------------------Aka Bucket-----------------------------------
John TC
Post by John TC » Wed Dec 11, 2013 5:52 pm
Did some work on the overhead vent system
so got all the bits together, I sand blasted and painted all the metal parts, fitted new rubber seal to the air control flap using pop rivets
glued new rubber seals on the air direction flaps
not able to find the correct grommets, I cut short sections of rubber pipe as a substitute
flap setup
John TC
Post by John TC » Tue Dec 31, 2013 12:50 pm
Ok Decided to make the day table over the xmas break.
started with a two pieces of 4mm marine ply cut and shaped to the table size.
I then made a frame with rounded corners and blocks to accept hinge/leg screws.
the shaped top was laminated with a spotty formica and the whole lot glued together.
I then edged it with oak which proved a problem on the curved corners
Back
top
I made a leg from solid oak (guessed the shape from pics)
I made a bracket to attach to the long side.
table catches and hinge, still looking for a friction stay for the leg.
Table in situ
Oh and Ive got some seat cushions :-)
lee c
Post by lee c » Tue Dec 31, 2013 1:36 pm
Nice mind!! 8)
OxonPhil
Post by OxonPhil » Tue Dec 31, 2013 9:16 pm
Very nice John :cheers:
And Happy New Year :D
Looking forward to more updates please :bounce:
Phil. :D
Post by e m p i » Wed Jan 01, 2014 7:55 pm
Aloha John,
Looking really good. That table is very impressive, just like everything else you've done :cheers:
Did you get the catches and the brackets on the bit of wood on the long side from that caravan supplies place?
Can't wait to see this on the road buddy.
Shalom, Lee.
John TC
Post by John TC » Thu Jan 02, 2014 8:40 am
Thanks for the comments guys
e m p i wrote:Aloha John,
Shalom, Lee.
Hi Lee. No the catches are original ones, not from caravan supplies, who do sell a similar type, TE5 in this picture.
They do exactly the same job just slightly different
John TC
Post by John TC » Thu Jan 02, 2014 10:01 pm
Today I made a couple of tapered legs.
and fitted them to the table using folding brackets, the type that locks in the open and closed positions.
Three legged table
Coolerdub
Post by Coolerdub » Fri Jan 03, 2014 12:36 pm
Words fail me on the quality of this restoration top notch bloomin marvelous is what comes to mind right now, keep up the good work must be nearly there now?
Ade
Always lurking here somewhere ;-)
John TC
Post by John TC » Sun Jan 05, 2014 8:38 am
Coolerdub wrote:Words fail me on the quality of this restoration top notch bloomin marvelous is what comes to mind right now, keep up the good work must be nearly there now?
Ade
Thanks for the kind comment Ade
Yes nearly there, I am enjoying every bit of the rebuild, but it amazes me how long all the little bits take.
OxonPhil
Post by OxonPhil » Sun Jan 05, 2014 11:20 am
John,
The bit I am most looking forward to is..............
You pulling up in the bus, and enjoying it :cheers:
Can't wait to see it now,
Phil. :D
P.s. Are you planning to have an awning rail on the bus ? (And if so how will you attach it ?)
John TC
Post by John TC » Sun Jan 05, 2014 8:56 pm
OxonPhil wrote:John,
Phil. :D
You and me both Phil
as far as an awning rail is concerned, if I can find one, I will fit it as per Devon spec, probably bolt it through the roof with seam sealer under its length.
Or I might rig something up using the sunroof opening to hold the edge of the awning.
irvmeister
Post by irvmeister » Sun Jan 05, 2014 9:07 pm
nice job your oing there pal, I have an awning rail somewhere :wink:
John TC
Post by John TC » Sun Jan 05, 2014 9:29 pm
irvmeister wrote:nice job your oing there pal, I have an awning rail somewhere :wink:
Exciting ------- Pm sent :-)
OxonPhil
Post by OxonPhil » Fri Jan 10, 2014 12:13 pm
John,
Are you going to have a magazine rack under the table ???
I'm not sure which years had that option ?????
Phil. :D
