Revenge of the monkeybus - Muddling through.
yakboy
Re: Revenge of the monkeybus - trimming out cab.
Post by yakboy » Mon May 11, 2015 1:23 pm
monkey wrote:Fitted the stainless steel separator trim and trimmed up the rubber base mats. It looks like it will be pretty tidy when it's completed. I resisted gluing it tonight, as I want to get it right and I think I'd just rush it tonight.
Pics tomorrow when it's done.
How did you bend the stainless trim? I still have mine to do and even a good friend who is an architectural metalwork designer is scratching his head to bend the WW stuff neatly. We are thinking of making up some in aluminium which will be easier to bend.
monkey
Post by monkey » Mon May 11, 2015 2:02 pm
It was a complete ******* to be honest. If you can find something similar in Ali, use it. The WW is too stiff and not fit for this purpose really.
Essentially MarkP and I worked out where the curve would be, Then snipped the flat section to allow it to bend easier. Then we inserted a small length of wire into the section where the bend would be to stop the section closing up. Then bent the section, then panel beated the flat bit to stop them sticking out everywhere. The only issue is that the wire is trapped, so around that corner, the rubber doesn't sit under the lip. Its not ideal but it was the only way we could get it to bend and look right.
The drivers side is a better fit than the passengers, which didn't bend as nice as the drivers side. They're not perfect by any means, but they're good enough for me not to worry too much about them. Most of it will be obscured by furniture anyway, so I don't think the flaws will show up too much.
'64 Devon Caravette - OG UK bus!!
'74 Karman Beetle - Imported Italian Dolce-Vita!
sbs#26 UK Chapter
yakboy
Post by yakboy » Mon May 11, 2015 2:12 pm
Thanks for the reply..your experience is exactly what I thought would happen. I am looking to get some custom Ali made and need to chase up my friend :roll:
monkey
Post by monkey » Mon May 11, 2015 4:09 pm
yakboy wrote:Thanks for the reply..your experience is exactly what I thought would happen. I am looking to get some custom Ali made and need to chase up my friend :roll:
Its fine for finishing flat surfaces, but not for bending. Its a ******* for bending!! :twisted:
sbs#26 UK Chapter
Rick T
Post by Rick T » Mon May 11, 2015 4:29 pm
I tried it for my walk thru also, someone gave me a full length of original Ali trim from the bottom of the bulk head, I thought it would be easier with the Ali but near on impossible. It's now in the bin.
Good luck mate with getting it sorted,
Rick
MarkFer
Post by MarkFer » Mon May 11, 2015 4:32 pm
Rick
Was it impossible even after heating/annealing the ali?
Rick T
Post by Rick T » Mon May 11, 2015 5:10 pm
From memory I put a piece of 4mm bar inside the trim then heated it up, it bent but pulled totally out of shape, problem is your not just trying to bend it round the corner but up as well then back straight, probably reason no one makes them.
Rick
Post by type21f » Mon May 11, 2015 8:27 pm
ying and yang ....balenced aura...
NICE...
Post by type21f » Mon May 11, 2015 8:29 pm
LOL...I answered in the wrong Monkey post or page...
monkey
Post by monkey » Tue May 12, 2015 6:43 am
Was you drinking heavily Graham? :lol:
sbs#26 UK Chapter
Post by type21f » Tue May 12, 2015 4:33 pm
No just normal for me....
monkey
Post by monkey » Tue May 12, 2015 8:50 pm
Painted my repro ambulance fans Airbox cover. Need to flat it as my spraying is ...., then polish it before fitting it. Apart from the gearshift and working out how to fit the seats (another story..) that will be the cab finished.
sbs#26 UK Chapter
Post by markp » Wed May 13, 2015 7:54 pm
you been a busy boy
Well done :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
Mark
monkey
Post by monkey » Wed May 13, 2015 9:42 pm
markp wrote:you been a busy boy
Mark
Yeah. Need to fit that bloody gear shifter again now! :evil:
sbs#26 UK Chapter
Post by e m p i » Thu May 14, 2015 8:09 pm
Glad to see you got the deluxe trim on the bumper in nice and tight 8) what did you use after all?
Cheers, Lee.
