UK 54
tango54
Re: UK 54
Post by tango54 »
Onto the other side. This is the bad side.
Fortunately I finally have a whole RH A pillar albeit LHD. It didn't take much to chop out the old.
The old compared to the new, I had time to remove the foot bar mount tube and weld it flush.
Interestingly the wing mirror mount appears to be fixed weld in nuts in the actual pillar with approx 12mm holes in the windscreen frame. The holes had been filled with lead, possibly as a fix up to mount the mirror.
Not sure on the mirror mount screw size, an m6 bolt is loose but an m8 is too large, probably stripped out m6?
The windscreen frame has a double reinforced plate behind the mirror mount holes, not seen that before but should be easy enough to replace.
tango54
Re: UK 54
Post by tango54 »
Sorted out the mirror mount on the RH A pillar.
Something like this
Welded in
And some zinc primer
Also sorted the inner valance before it gets welded in
Scotty
Re: UK 54
Post by Scotty »
Keep up the good work!
Vwstu
Re: UK 54
Post by Vwstu »
Wow looking really good👍
[b]Ratty dove blue 59 panel van[/b]
karl040
Re: UK 54
Post by karl040 »
SamCocker wrote:
Fri Oct 24, 2008 4:50 pm
Hi Alex, Very nice bus you comparateur assurance chien have there, looking forward to seeing more pictures
Sam
Hello!
This is a good picturr because there are many tips and also many advices that will be very useful to me.
