My Second VW !! mid life crisis ...The 1966 vert
markp
Re: My Second VW !! mid life crisis ...The 1966 vert
Post by markp » Sun Feb 10, 2019 9:54 am
8) 8)
HI ya
Then it was time for the sides of the floor to go in .... Excited to see some panels going back in as it makes him look complete again
Every step taken is a step closer to the end :cheers: :cheers: :cheers:
So with one side lfe to do ... maybe I can get out there today for one hour and get the other side of the floor welded in so on Monday evening its a night of tyding up welds
:cheers: :cheers: :cheers: :cheers: :cheers:
Well that brings you all upto date
Over and out
Mark p
nige1171
Post by nige1171 » Wed Feb 13, 2019 1:49 pm
Nice work Mr P! Quality and speed in equal measures :D
That beam does look good too!
Nige
My build thread...
viewtopic.php?f=8&t=69457
Post by type21f » Wed Feb 13, 2019 1:57 pm
Progress is faster on Facebook.. lol
markp
Post by markp » Thu Feb 21, 2019 7:00 am
Yep .... thing is its so much easier to chuck a photo onto FB ..... I do bigger updates here
Photo on FB are just for my ref and album
Things are going well and I've started doing some filler work too ..... Update coming soon once I have more photos to sure
Mark p
Post by type21f » Thu Feb 21, 2019 7:52 am
Try tapatalk!
Easy!
9 pictures at a time then post and save and then edit go back in move pictures around add text and add more pictures! IT IS EASY..I can even do it!
Karl_F
Post by Karl_F » Thu Feb 21, 2019 8:35 am
Top work Mark, pretty sure Lloyd ran his Dogback air beam directly from a compressor to avoid having to install a tank.
Karl
1960 Mango 11 window
Mango build thread
markp
Post by markp » Sun Feb 24, 2019 8:56 am
Good heads up mate ... thank you
BIG UPDATE ON ITS WAY :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
Mark p
markp
Post by markp » Sun Feb 24, 2019 9:11 am
A few updates to post this morning as threads behind on where I'am now
So here we go
We all know the rear fllor was a mess and needed some propper time putting into it to make it good again
Here's a little flash back for you
Yep lots to do there .... it was always going to be the best way ....REMOVING IT for Bert
My thinking around removing it was that it
1) be easier to do out side of the shell
2) I didnt have to roll around on the floor
3) i could pop the floor onto the pan and use it as a jig to line up the rear mounting points the go under the rear seat area
and the plan worked out a treat .... super happy with how it all looks now and so I popped it into a thin coat of primer and sealed it .... I will just quickly key this area up when I finish the rear end off and then pop it all into high biuld primer and then move onto the front end ......
Second update on its way in a few mins
ps the photo below is obviusly in the wrong place but i can even see it on my post update page .. so I cant remove it sorry x
Mark p
markp
Post by markp » Sun Feb 24, 2019 9:35 am
Then it was time to repair the lower rear wings
They were rotten and also by cutting that area out it allowed me access to welding all the shell onto the heater channels and it would ALL be hidden welding thus making it a really neat job and also no cleaning up of the welds so leaving the welds as they are ... super strong :cheers: :cheers: :cheers: :cheers: :cheers:
Any way onto the job in hand
Had to pop all the panel back on to check all wholes line up with the wings so when i come around to bolting it all together after his painted I'll have minimal problems :cheers: :cheers: :cheers: :cheers: :cheers:
So then onto the fitting of the side lower panel
All pinned on in place to check everything ok and I'm happy with the fit
So thats all good after a little fettering
time to weld it all in and onto the next task .... The repair needed to the top of the rear wing
This area here :oops: :oops: :oops: :oops: :oops:
and how it looked after blasting
Next update cover the repairs in this area
Over and out peeps
Mark p
markp
Post by markp » Sun Feb 24, 2019 9:40 am
Here we go again
so I could just do this and say here it is all done and show you nothing and take the easy root
and do the old before and after shot
But that would be boring and help no one ..... so lets see how i did it hu
markp
Post by markp » Sun Feb 24, 2019 9:47 am
so my first job was to make a template up of the panel that was needed ....
So out comes the aper and sizzors ( spelt wrong i know ) :oops: :oops: :oops:
I then made sure i checked out the hight the panel would have been ... I could see that there was a few bits left of the oringinal panel thus giving me the hight of the panel needed to be made
and that check out the fitting of it
Al looking good so far .... so happy with that I cut the metal out that i was going to use
A few more checks and i'd be cutting out the rusty old bits on Bert and prep for fitting newly made panel
NOTE .... the swage line i'd also put into the newly made panel ..... lines up nice with the swage on the rear wing :cheers: :cheers: :cheers: :cheers: ssswwweeeeeeetttt
Happy with that
Mark p
markp
Post by markp » Sun Feb 24, 2019 10:02 am
Dam ... its update spoilt time hu peepes
you Pervs are loving it ..... freaks !!!! hehehehe ... enjoy as here we go again
so I noticed that there was a fould on the original panel as arrowed below .... anyone noticed me arrow skills have improved sinse Gerrys resto :cheers: :cheers: :wink: :wink: :wink:
so I had to make the panel the same or it would not be correct to have both sides differant .... I know they will never been seen but at least I know its right :cheers: :cheers: :cheers:
so a cut a thin bit of metal and shaped it to the arch of the panel and then welded them togeth
give is all a clean up and hey presto .. panel sorted
so next step was to repair some bits on the inside of the panel as they had rusted though ... this area is where the wood for the hood sites and bolts down on so it needs to be good and strong .... so i cut and the rust and made a new little panel and welded that sucker in ....Job done
Happy with that it was time to weld in the outer repair bit I already made
Mark p
markp
Post by markp » Sun Feb 24, 2019 10:20 am
wow
here we go again
So time to weld the peace in a made
Then I decided to have a little go at lead loading
Never done it before 8O 8O 8O 8O 8O 8O
was not too bad to do ... My skill level with this as low so I couldnt finish in it but it was fun to try and have a go
the trick is dont heat it up too much or you will loose it all on the floor .... watched a few you tub vid's before trying it
clean clean clean the panel first
the brush solder on to panel
heat up solder and wipe of with a non fluffy cloth
the solder turns a silver shinny colour
then heat up lead stick and panel all at the same time and start dabbing panel with lead leaving behind lead mountings on the panel .... the get your wooden paddle out and heat up lead and push it around where needed .. just like body filler really
it also sands down well and you can also rub it with sanding down paper just like filler
result was good and then I finished off with a scim of body filler
Happy with the out come
and then I finished off the repairs to the rear wing
ALL DONE ON ONE SIDE AND NOW ONTO THE REAR PARCEL SHELF AREA
Getting there slowly but surely
Mark P
markp
Post by markp » Sun Feb 24, 2019 10:24 am
and just in case we forgot what we started with
BOOOOM
Over and out
Mark P
Post by vwJim » Sun Feb 24, 2019 10:58 am
Loving the arrow skills... Lol
