Double Door project.
Brothernumberone
Post by Brothernumberone » Sun Mar 11, 2018 11:00 am
Hello. This is my '66 double door Swedish bus which I'm restoring. It's spent quite a bit of time in a field, hence the lichen;)
Brothernumberone
Re: Double Door project.
Post by Brothernumberone » Sun Mar 11, 2018 7:38 pm
It's very rusty in the middle, but strangely not at the front or rear. I had some chassis sections made up and replaced the middle bits. Used Schofields's panels for the sections from just behind the beam back to the front outriggers. Made up the reinforcement bit on the inside of the chassis just behind the outriggers.
Brothernumberone
Post by Brothernumberone » Sun Mar 11, 2018 7:39 pm
A few more
Brothernumberone
Post by Brothernumberone » Sun Mar 11, 2018 7:41 pm
:wink:
Brothernumberone
Post by Brothernumberone » Sun Apr 01, 2018 3:11 pm
A few more pics and an update. Not had a lot of time due to paid work getting in the way, but now that the chassis sound again, I've started on the rest. Bulkhead bottom edge repaired, then new top hats and cross members and heater tube.
'Box and shafts out to get the shift rod out so I can replace the shift rod guide tube and also replace the nose cone which is snapped. Presumably because someone's jacked the van up on the 'box.
Glenn Yale
Post by Glenn Yale » Sun Apr 01, 2018 8:15 pm
That looks great. What are you plans for the exterior, full resto or leave as is?
Brothernumberone
Post by Brothernumberone » Mon Apr 02, 2018 8:39 am
Cheers! Not sure on paint yet, will get it welded and drivable first, then maybe I'll paint it at a later date.
Brothernumberone
Post by Brothernumberone » Fri Oct 12, 2018 8:59 pm
Been a bit busy with customer stuff recently so I've only just got back on this. Got the cargo floor down, Wolfsburg West panels are ace!
Decided to get the van back on its wheels before starting on door gaps, so cleaned and painted the gearbox and axle which were out from when I did the shift rod guide tube. One drum wouldn't shift so had to improvise a puller using a sacrificial knackered wheel 😉
With the van back on the ground, I got started on the sides. New b and c pillars, rear arch, outer sill and strengthener, and cargo door bottoms.
vwbuzzers
Post by vwbuzzers » Mon Oct 22, 2018 1:22 pm
Looks your cracking on good work.Sounds like a good idea to put the bus back on wheels before sorting out the doors. Never done it myself.
Buzzers
Brothernumberone
Post by Brothernumberone » Wed Oct 24, 2018 8:52 pm
Buzzers
Cheers! It's been a battle. The doors had been adjusted to compensate for prior movement or sag. With hindsight, I should have corrected the gaps before welding stuff back in and making it more rigid. All good now though👍 Another two to go as it's a double-door😂
