66 rhd dove blue
- SSVC Member
- Contact:
Re: 66 rhd dove blue
Gaps..
Next new cargo door skins and seat belt mounts
- SSVC Member
- Contact:
Paint prep time
Hiya
Could I be cheeky please & ask if you can measure something for me..!!!only when it's convenient....
I'm after the length of the frame horns (chassis legs)..
I have two measurements of 52cm or 51cm,?? running along the side of the frame horns from the face of torsion tube...too the bolt end of frame horn.. I need too know which one is correct...!!!???
Thankyou
Marc
Thankyou
Marc
- SSVC Member
- Contact:
Sure thing! I will check on Monday when I get to work!
That would be great..Thankyou..
Marc
Marc
- SSVC Member
- Contact:
Slowly getting there...
Hiya
Please when you get chance could you measure one of the frame horns length for me...my van is a 65...... It would be truly appreciated...
Thankyou..
M
Thankyou..
M
- SSVC Member
- Contact:
Body is painted and is now being flatted and polished
- SSVC Member
- Contact:
Hivolksair wrote: ↑Thu Jan 18, 2018 3:55 pm Hiya
Thankyou
Marc
Running a tape flat on the torsion tube to the end of the horn it’s 513mm, from the furthest point ie bottom lip of the horn on the torsion tube it’s 550mm.
Hope that helps you.
Kind regards
Will
Absolute legend & very kind..
Thankyou, yes extremely helpful.. The 550 is a great extra datum & the 513 is almost the 510 I was told previously so I can weld the frame horns on now.... Once again.. Thankyou for your time...
M
M
- SSVC Member
- Contact:
Not a problem
- SSVC Member
- Contact:
Lots of priming later the engine bay is ready for paint.
- SSVC Member
- Contact:
Engine bay and chassis finished, few more bits to do then it’s done!
- SSVC Member
- Contact:
Put a bit of blue down over the last few weeks.
- SSVC Member
- Contact:
Fitted up ready for Jim.
