Single Garage Resto...
Re: Single Garage Resto...
Post by type21f » Sat Oct 01, 2016 1:18 pm
Real progress being made...
Keep going..
oilyragg
Post by oilyragg » Mon Oct 03, 2016 9:26 am
Painted the roof and cab in beige grey and although I was happy with the spray out card I'm not sure I like it on the bus. I'll give it time and see if it grows on me.
susta
Post by susta » Mon Oct 03, 2016 1:35 pm
thats because you've got all those funny marks in it from your tent , looks great, you liked my colours at Busfest
Post by ted698 » Mon Oct 03, 2016 3:27 pm
Once you get the main colour on there it will look great..... paint looks great by the way!
Post by e m p i » Wed Oct 05, 2016 7:24 pm
Wow loads of progress, well done.
wejjy
Post by wejjy » Sat Oct 08, 2016 9:56 am
Looks incredible, nice work!
oilyragg
Post by oilyragg » Mon Nov 07, 2016 2:08 pm
Not updated for awhile as I've been on holiday (Iceland) and also because I have been rubbing down the roof and cab again. I just couldn't make myself like the beige grey and believe me when I say doing it again was the last thing I ever wanted to do! But I'd rather do it now than later so a new colour was found.
It's a lot whiter but still has a bit of creaminess about it and I really like it this time!
Look out for 4 litres of beige grey coming up for sale lol.
oilyragg
Post by oilyragg » Thu Nov 24, 2016 7:12 pm
Managed to get the cargo and cab doors rubbed down and into high build primer then fitted with all the catches and leavers to recheck the fit.
Then it was onto fitting the new deluxe trim from creative engineering, sorry about the pic but it was dark when I finished. I'll finish off the long sides at the weekend when I have more light!
oilyragg
Post by oilyragg » Sat Nov 26, 2016 2:28 pm
Finished off the rear deluxe trims, much easier than I thought to bend round the rear corners then cut them to size and filed flat. The hardest part was making sure the drill was centred in the trim hole as the screw could pull it out of alignment so found a good life hack, a bit of brake pipe fitted perfectly in the hole and stopped the chuck from damaging the trim.
Then it was just a case of counter sinking the screws by carefully running an oversize drill bit into the holes so screws will sit flat and not have lumps in the plastic inserts.
SplitBusVanatic
Post by SplitBusVanatic » Sun Nov 27, 2016 12:19 pm
Good thinking. Gonna be a lovely bus when it's finished.
AdrianReeve
Post by AdrianReeve » Sun Nov 27, 2016 8:17 pm
I recognise that deluxe trim! Bus is looking great, look forward to seeing it progress.
oilyragg
Post by oilyragg » Sun Nov 27, 2016 9:04 pm
AdrianReeve wrote:I recognise that deluxe trim! Bus is looking great, look forward to seeing it progress.
Yep that's your old trim Adrian! Thanks buddy fits really well.
In fact quite a few bits have come from you guys:
Magic8ball supplied the B-post
Orange supplied the rolling jig
One eyed duck supplied the lower rear corner
And markp supplied the ace sealer
A big thanks to all you guys and I'm still not finished buying yet!
Anyone got a under dash tray?
oilyragg
Post by oilyragg » Sat Dec 10, 2016 3:32 pm
I have been rubbing down the primer all week after work with the aim of getting it into the spray booth at the weekend and luckily I got a space today so in she went for a coat of Campanella white.
oilyragg
Post by oilyragg » Mon Dec 19, 2016 1:20 pm
Finished rubbing the doors down and also gave them a coat of white inside and out and sealed up the gaps round the hinges.
susta
Post by susta » Fri Dec 23, 2016 7:41 pm
Cool as the cars that are in there
