Single Garage Resto...
vwbuzzers
Re: Single Garage Resto...
Post by vwbuzzers » Thu Sep 08, 2016 10:35 am
Wow your one talented motivated guy. It's an inspiration for those trying to use space or lack of it as a reason not to get cracking. Me included lol
Buzzers
Post by e m p i » Thu Sep 08, 2016 4:03 pm
Good progress going on there mate 8)
Now you've got the garage space any chance I can come and dump some of my collected junk in it for storage? I imagine Graham t21f wouldn't mine some storage space as well :lol: :lol:
oilyragg
Post by oilyragg » Thu Sep 08, 2016 6:35 pm
e m p i wrote:Good progress going on there mate 8)
Lol even after the garage is missing a bus it's amazing how quickly an empty space fills up! Now it has doors, bumpers, windows and a gearbox which will need a straight axle job doing to it. Watch this space :roll:
Post by type21f » Thu Sep 08, 2016 7:25 pm
...Space? The Final Frontier....
Possessions expand to fill the space availble..
I am downsizing..
I am selling things off..
What? she says
How many items have you acquired this year?
Several!
How many have you sold?
One!
Well it is a start..
I will do it..
I just get attached to things..
LOL
oilyragg
Post by oilyragg » Tue Sep 13, 2016 6:48 pm
Drilled hole for one eyed duck and bought some rear lights from Busfest, first time they have been test fitted since I cut out the hole but they both fitted well.
Shot blaster missed a few bits in the engine bay so after a bit of sanding and some fertan I gave it another coat of epoxy.
oilyragg
Post by oilyragg » Wed Sep 14, 2016 5:36 pm
Tonight's job was to seam seal the engine bay.
oilyragg
Post by oilyragg » Sat Sep 24, 2016 8:11 pm
Prepping roof and cab area for colour next week!
And painting the straight axle parts ready to tackle the gearbox. Got new bearings and gaskets but I'm expecting a bun fight.
jasonjleach
Post by jasonjleach » Sun Sep 25, 2016 9:04 am
Looking good there, what you planning to do with the transmission case, powder coating?
1st time project!
oilyragg
Post by oilyragg » Sun Sep 25, 2016 9:18 am
jasonjleach wrote:Looking good there, what you planning to do with the transmission case, powder coating?
1st time project!
It cleaned up well so I'll leave it as is. It's a bit of a gearbox gamble as it was given to me in unknown condition. All the selectors work, the drive shafts turn and the clutch leaver is free so fingers crossed it's a good one.
oilyragg
Post by oilyragg » Tue Sep 27, 2016 8:53 pm
Started deconstruction and the first problem was one of the bearings was stuck on but found a puller and eventually it came off.
I found when putting the axle tubes on they would get tight when I knocked the bearings into the carrier but after turning the axle it all freed up so it was a case of tap/turn tap/turn until bearing was seated.
Gearbox fitted into the bus with no problems and I was always concerned the gear shift tube might not line up with the nose cone but it was spot on and the axle tubes were on the correct side. Phew.
When I fitted the spring plates to the carriers I found there was a big gap between the two...
But after a few facebook posts (thanks guys) I was told not to worry as it was normal.
Was not sure how high to put the spring plate on the torsion tube but after a call to T2D they recommend around a 10mm gap up from the bottom of the torsion tube.
And finally four wheels on the bus. I still have to clean up and install the back plates but at least the bus can roll now.
W-W
Post by W-W » Wed Sep 28, 2016 7:47 pm
What adapters do you have for the porsche to 205, did you get them made up.
Great job, proper job.
Sent from my SM-G900V using Tapatalk
oilyragg
Post by oilyragg » Thu Sep 29, 2016 6:40 am
W-W wrote:What adapters do you have for the porsche to 205, did you get them made up.
Sorry buddy no Porsche parts on my bus it's all VW
W-W
Post by W-W » Thu Sep 29, 2016 7:56 am
Oh is that a standard red 9 disk and adapter, the inner studs look like porsche but they must be bay.
I've got Porsche hubs so I've not seen a standard one.
oilyragg
Post by oilyragg » Thu Sep 29, 2016 9:07 am
W-W wrote:Oh is that a standard red 9 disk and adapter, the inner studs look like porsche but they must be bay.
Yes mate standard red 9 in the front
oilyragg
Post by oilyragg » Sat Oct 01, 2016 1:11 pm
Roof and cab area rubbed down, time for paint!!!Image
