Single Garage Resto...
oilyragg
Re: Single Garage Resto...
Post by oilyragg » Sat Jul 08, 2017 7:53 pm
After a 12 week wait I finally received my servo from creative engineering, at the time vwjim was out of stock so I went to CE thinking they had some as the website didn't say they were also out of stock but were happy to take my money Image lesson learned.
Made a new bracket for the servo and made the rest of the brake lines this morning, it's a really tight squeeze under the bus so I'm more than happy to get it done in a day.
Let's hope they don't leak when I bleed them Image
wizard 1066
Post by wizard 1066 » Sat Jul 08, 2017 8:50 pm
Neat job, looks like the same servo Jim sells, and all the fitings look to be in the same place, its one of the best conversions to make the brakes easier to use, and no longer having to stamp on the brakes and more feel on the pedal.
oilyragg
Post by oilyragg » Sun Jul 16, 2017 4:48 pm
So much for no leaks, I used a pressure brake bleeding system so I could do the job on my own, basically you use air pressure from a tyre to pressurise the system (10-20psi) then open a bleed nipple and the fluid will flow out.
First time I did it fluid came out of the front T piece
My mistake was using a small union in the top of the T as it's longer than the sides so didn't clamp the pipe properly and as a result it leaked. So I cut the end end off and replaced with a longer union, new flare and tightened up. Problem solved.
Pressurised the system again and noticed lots of weeping from various unions, I was obviously being over cautious and not doing them up tight enough, so went round every union again and gave them all a few more turns. Time to bleed the brakes again.
Long story short pedal kept pumping up and air always in the system Image after checking all the joints again, checking wheel cylinders and servo I found the new brake light switch was at fault Image went out and bought a new one and another leak sorted.
Good one on the left crap one on the right (avoid)
Pressurised the system once again only this time the seal in the top of the reservoir blew out, don't forget I'm doing all of this on my back under the bus so I got covered in brake fluid for the second time loosing half litre of fluid in the process. Binned the pressurised bottle and called the wife into the man cave to do it the old fashioned way of pumping the pedal which worked first time so now I have a good brake pedal at last!
oilyragg
Post by oilyragg » Sun Jul 30, 2017 1:47 pm
I tapped a thread for a tail into the manifold, all was going well until I got it all back together. I added the servo hose to the tail but decided I wanted to route it differently, I pulled the pipe off and managed to rip the threads out of the manifold, disaster.
So I ordered the next size up (1/4 bsp) took it all apart again, re-tapped the manifold and reassembled for the second time but with a much better fit this time, with hindsight the first tail was to small.
Bought some stainless steel clips to secure the servo hose and added a one way servo valve to finish off the job. Hopefully brakes are now all finished.
I thought long and hard as to what tyres to fit and decided on 165/65/15 for the fronts and 175/65/15 for the rear. I had only the fronts fitted because I wanted to try them on the rear first in case they rubbed on the rear swing arm adjuster and sure enough they did, so I mocked up some 10mm spacers and I had clearance but not enough for 175 tyres so it looks like I'll run 165s on the rear as well.
New 10mm spacers on order along with longer wheel bolts.
New stainless hub caps fitted
oilyragg
Post by oilyragg » Sun Aug 06, 2017 12:28 pm
Got the bus out the garage so I had room to get the door frame on and fit the door mirrors. once again the new rubbers are pushing the door down so I fitted it and made sure all the rubbers were facing outwards and shut the door. I'll leave it that way for a few weeks for them to bed in.
A bit of good news bad news over the weekend with regards to the bus, she drove for the first time under her own power up and down the drive.
Which means I can get 1st 2nd and reverse gears but 3rd and 4th were not engaging. I assumed it was the plate adjustment but after many tries it still wouldn't find 3rd or 4th. I took the gearbox coupling off of the shaft and tried moving the hockey stick in the gearbox by hand but although I can feel the hockey stick click into the 3rd 4th selector it will not budge. Either the hockey stick is not quite lined up with the selector or the selector itself is stuck. I checked all the gears before I installed the gearbox and all was ok but now it looks like I will have to pull the engine and gearbox back out so I can get the nose cone off to see what's going on unless you guys have any other suggestions? Image
Ronnie T
Post by Ronnie T » Sun Aug 06, 2017 8:00 pm
Oily Rag,
Before you take it all apart try getting all gears from the hockey stick using mole grips without damaging the stick.
If you get all gears it may be the positioning of the dimple.I fitted a new hockey stick and had the same problem as yourself.
I rectified it by cutting and repositioning the collar on the front rod by a few mm and redrilling the front shift rod to match the collar if that makes sense.
My new hockey stick had a different dimple position which put it all out of whack.
oilyragg
Post by oilyragg » Sun Aug 06, 2017 8:42 pm
Oily Rag,
That's what I've tried Ronnie, I can move the shifter into 1st 2nd and reverse using the hockey stick with everything disconnected but 3rd 4th shifter is stuck.
Ronnie T
Post by Ronnie T » Mon Aug 07, 2017 6:37 pm
Did you fit a different nosecone on yourself and ensure the hockeystick was in the neutral position prior to fitting allowing a full sweep through the selector rods?
If you were able to find all gears then its strange that you cant when the gearbox is bolted up.
Do you think your getting the full movement of neutral and the rod will not move back and forth?
oilyragg
Post by oilyragg » Mon Aug 07, 2017 6:51 pm
All I can think of is that the selector moved out of neutral when I put the nose cone on, but I've already got the engine out and the gearbox is almost out as well so if I have time I'll find out tomorrow.
paul_f
Post by paul_f » Tue Aug 08, 2017 7:52 am
If the shift rails were not in the right place then you wouldn't get any gears - or you would be stuck in 3rd/4th.
It can be difficult to put it in gear when the engine isn't running , as the box relies on rotation to align and engage the gears. Before taking the box out try engaging it from underneath (and in the air) whilst someone is turning the input shaft
oilyragg
Post by oilyragg » Tue Aug 08, 2017 6:34 pm
Took the nose cone off and found the 3rd/4th selector was seized but not by much, a quick knock with a hammer and a lot of lubrication and some pushing and pulling action freed off the selector. Gearbox is back in and I now have all gears :cheers:
Tomorrow's job is to put the engine back in :D
oilyragg
Post by oilyragg » Sat Aug 12, 2017 2:09 pm
Time to put it back in...
Job done, with engine running I now have all gears Image
Post by JonnyCJ » Sat Aug 12, 2017 7:53 pm
Your rubbers shouldn't push the door down that much. The hinges have greater upwards force than the downwards force from the rubbers.
I'd take the door frames off and get the swage lines and striker plate perfect so that you have a datum point to work from.
Then ensure that the cross bar on the door frame is in alignment with the bottom of the quarter light frame. There's a few mm of movement on the cross bar vertically and it can make all the difference.
https://www.ssvc.org.uk/phpbb/viewtopic ... ps#p900360
Ask me how I know :roll:
oilyragg
Post by oilyragg » Mon Aug 14, 2017 7:21 pm
Dug the tail gate out and found some tin worm so cut it out...
Made a patch...
Welded it up.
oilyragg
Post by oilyragg » Sat Aug 19, 2017 11:19 am
Filled up the tailgate, needed a bit more than I thought as it was quite badly dented but when it was done I set them up for a bit of high build primer session this morning. That is the last of the bits that need painting!
Got home and went into the man cave to fit new lowered shocks to the rear.
