Single Garage Resto...
Re: RE: Re: RE: Re: Single Garage Resto...
Post by type21f » Sat Feb 11, 2017 10:53 pm
JonnyCJ wrote:
type21f wrote:
JonnyCJ wrote:
Looks like you're also missing the rubber stop for the clutch pedal https://www.customandcommercial.com/vw- ... 55-79_186/
Easy to fit in a warm garage, might be worth warming it indoors first to get the rubber plug through the hole without it tearing.
:D
I did not buy one and have had an issue if you 'stand on' the clutch pedal it did stick down a couple of times...
Alarming the first time it did it...but easy to pull it back up with foot or hand..
Not done it recently.
I was convinced it was a cab belly pan issue..
LoL
Clutch release spring lever arm thingy (at the gearbox end) should pull the clutch cable back and therefore pull the clutch pedal back up. Could be you had a Bowden tube issue which self corrected ?
Get me - knew 0.000% about buses when I bought mine and here I am giving advice 8O
Lessons of life...
Every day is a school day..
oilyragg
Post by oilyragg » Sun Feb 12, 2017 1:36 pm
Man cave is just too cold today, it's even snowing outside so I did a bit of cleaning and painting on the gear shift rod in the warm plus added a new bush. That's it for today.
oilyragg
Post by oilyragg » Tue Feb 14, 2017 7:36 pm
Headlights in and wired up but the rubber seal that goes round the bowl is way to thick and pushes the headlight out of shape so I've left them out until I find a better solution.
All gear rods connected up and a short shift plate added to the gear stick, it seems all gears are there but time will tell.
Post by type21f » Tue Feb 14, 2017 8:08 pm
Maybe make some out if sheet rubber to fit..using the ones you have as templates..
...and then return them for a refund..
Or use the originals..
oilyragg
Post by oilyragg » Tue Feb 14, 2017 8:29 pm
type21f wrote:Maybe make some out if sheet rubber to fit..using the ones you have as templates..
That's a good shout, I've got some sheet rubber lying about I'll give that a go. :cheers:
rusty1962
Post by rusty1962 » Thu Feb 16, 2017 7:28 am
I sanded the rubbers down using a bit of sandpaper on a mallett. Took ages but I got them in....
visit my webshop
Halso Aircooled VW Oil
oilyragg
Post by oilyragg » Sun Feb 26, 2017 2:23 pm
Taking a break from all the wiring and did some sound deadening instead.
rusty1962
Post by rusty1962 » Sun Feb 26, 2017 3:56 pm
I found this stage quite therapeutic.....not too much thinking required :D
Looking very tidy :cheers:
visit my webshop
oilyragg
Post by oilyragg » Tue Mar 28, 2017 7:16 pm
6v armature replaced for a 12v one on the wiper motor, looks in good condition too.
One of the hardest jobs so far, fitting the headliner, still a lot of creases from the folding of the material in it. Not to sure how to get these out but I'll have a chat with a trimmer and see what he recommends.
Switches and gauges in and finished wiring up.
And a better view of the windows...
That's it for now.
rusty1962
Post by rusty1962 » Tue Mar 28, 2017 8:56 pm
Your posts take me back and I remember doing all the same stuff. It's looking great!
visit my webshop
Post by type21f » Tue Mar 28, 2017 10:58 pm
rusty1962 wrote:Your posts take me back and I remember doing all the same stuff. It's looking great!
I am looking forwards to getting Sherry here..
Looking very nice...
oilyragg
Post by oilyragg » Mon Apr 03, 2017 5:44 pm
First time a battery has been fitted in 20 years, no fire yet and we have working lights, gauges, wipers and the starter motor turns Image plus a new rear view mirror has been added as it never had one before Image
Post by type21f » Mon Apr 03, 2017 6:24 pm
oilyragg wrote:First time a battery has been fitted in 20 years, no fire yet and we have working lights, gauges, wipers and the starter motor turns Image plus a new rear view mirror has been added as it never had one before Image
Mirror not fitted more usual than I realised.
My 62 did not have a VW mirror fitted..
Had aftermarket version..
rusty1962
Post by rusty1962 » Tue Apr 04, 2017 7:34 am
Always nice to switch on the lights and see it all light up after spending quite a while fitting terminals and pulling wires!
One of those moments :cheers:
visit my webshop
oilyragg
Post by oilyragg » Mon Apr 24, 2017 6:51 pm
The brakes were next on the list so cleaned up and painted the back plates and fitted new shoes
Then on to making new brake pipes
Welded up the catch plate holes used a bit of ally to stop the weld penetrating to far into the frame stopping the catch plate from fitting (going to bond them in) and repaired the door tops.
Stated repairing the under dash tray, the wife won't be happy as she was using it as a colander.
Rubbed down and repaired the bumpers and then it all went into primer
