Single Garage Resto...
Rick T
Re: Single Garage Resto...
Post by Rick T »
Very nice, and you make it look very easy.. towed my nuts off with just about every job on mine!!
Rick
oilyragg
Post by oilyragg »
Lol thanks Rick but it's not all plane sailing.
Master cylinder with brake pedal in place and clutch cable fed through to gearbox. Accelerator cable is in as well whilst I was under there. Might upgrade to a buttys bits throttle kit if funds allow.
You're missing the rubber boot that goes over the pushrod end of the master cylinder and protects (to an extent) the master cylinder.
I just happen to have a spare, so PM me your addy and I'll pop it in the post.
Jonny
oilyragg
Post by oilyragg »
JonnyCJ wrote:You're missing the rubber boot that goes over the pushrod end of the master cylinder and protects (to an extent) the master cylinder.
Jonny
Thanks Jonny I just found it in the bottom of the box :roll: I'll put it on tomorrow.
Ha ha ! Glad to have helped.
wizard 1066
Post by wizard 1066 »
Any idea what steering rack they use on the red 9 kit, I was one told they use mostly VW stuff off the shelf, as in the t25 bevel box at the bottom of the steering shaft, and items like ball joints so they can be sorced easily when they wear out.
susta
Post by susta »
Give Simon a call
wizard 1066
Thanks I will do, just asking as I have been considering the set up for our van.
Jonny
Looks like you're also missing the rubber stop for the clutch pedal https://www.customandcommercial.com/vw- ... 55-79_186/
Easy to fit in a warm garage, might be worth warming it indoors first to get the rubber plug through the hole without it tearing.
:D
Re: RE: Re: Single Garage Resto...
JonnyCJ wrote:
oilyragg wrote:
JonnyCJ wrote:Image
Jonny
:D
MMMM Can you post a picture showing location of where this stop goes?
I do not remember removing one or fitting one.
I did not buy one and have had an issue if you 'stand on' the clutch pedal it did stick down a couple of times...
Alarming the first time it did it...but easy to pull it back up with foot or hand..
Not done it recently.
I was convinced it was a cab belly pan issue..
My old Audi did the same but a mineral oil soaked foot one day confirmed my suspicion it was a seal issue on the clutch master cylinder..
LoL
oilyragg
Post by oilyragg »
Jonny
:D
Thanks Jonny, It looks like I have it in a box somewhere so I'll dig it out later and the rubber boot is also fitted :cheers:
oilyragg wrote:
:D
CHEERS
So how does that work with a mat?
Must be where I have not looked.. INSIDE
Had oiter cab floor quarter sections replaced in corners..
Off to look at 1000 pictures..LOL.
To find Before..
oilyragg
Post by oilyragg »
type21f wrote:
:D
CHEERS
To find Before..
The large square part goes underneath the floor and hits on the clutch arm not the pedal so doesn't effect the mat.
Re: RE: Re: RE: Re: Single Garage Resto...
oilyragg wrote:
type21f wrote:
CHEERS
To find Before..
Ah that would be the original one refitted after all..
See it better from this angle
Cheers...
Not that then..
So adjusting the belly pans did seem to cure...
:D
LoL
Clutch release spring lever arm thingy (at the gearbox end) should pull the clutch cable back and therefore pull the clutch pedal back up. Could be you had a Bowden tube issue which self corrected ?
Get me - knew 0.000% about buses when I bought mine and here I am giving advice 8O
