Fergy
MartRogers
Fergy
Post by MartRogers »
Well I acquired this a few months back and decided it's time I got some pictures up before I lose them , it's a 1960 panel which appears to have been laid up in Alabama since 1974 going by the magazines and newspapers I found in the back. Plan is to repair rust, age as well as I can and run it stock. Initial plan was to ship it off for the welding but I quickly realised that would bankrupt me as I am also doing a lot of work on the house at the same time. Couple of pics for now . ImageImageImageImage
MartRogers
Re: Fergy
So have brought myself a welder after not touching one for about 15 years and in at the deep end !
MartRogers
Fergy
First bit of panel making and welding, gone from this Image
To this Image
MartRogers
Re: Fergy
Top hats , heater tube and I beams out, what a crap job Image
Then new ones in along with b post inner and outer repairs and inner sills and step.
Onto this mess now
Went quite well and all ground back have me this
Had to fill the welds in a few times to get rid of pin holes as filler is not an option as it won't rust :)
Few Sprays with hydrogen peroxide and it's getting there, will match up better once the whole bus is anchor waxed
Then rear quarter , repair panels I have didn't have any lip to the wheel arch so decided to keep as much og as possible by cutting the required sections from the panel
Ground back with first coat of peroxide
And coming along nicely
Put a battery on this night also just for the hell of it and was shocked that almost all of the electrics including the bulbs and indicators still work ;)
That will do for now,
BlastingDiePast
Re: Fergy
Post by BlastingDiePast »
Nice work!
What colour you going to paint it......... . ... . . .
MartRogers
Re: Fergy
Ha it may well get painted ... ...... When I'm dead
MartRogers
Re: Fergy
Then the one I was dreading, the metal is pretty thin on the long side so was expecting a lot of trouble. I enlisted the help of a chap from the pub who is an old school panel beater by trade who gave up his Sunday and worked some true magic
Dont seem to have any before pictures for some reason but it was in a bad way
Then spent an age grinding it all back, one thing to note we left all the strengtheners out at this point as they were all rotten and there was a bit of damage down the side that had been filled at some point, due to the fact it needed some beating nick just went for it and welded the whole side in about 20 mins, he then set to with his dolly and it was arrow straight in no time. Unfortunately I then welded all the strengtheners in and managed to pull part of the panel in so had to redo this area. All looking good now though
Bit of potion and a few more repairs above the line which turned out to be about ten pin holes that became much more than that ! Still needs some more potion buts it's getting there
Then moved onto the rear inner arches, closing panel in
And rear front and back with battery tray and a few repairs to the side and engine side tray, the side tray was in a bad way but was worth spending time on as chassis number stamped here.
And this bit is getting a bit of paint.
MartRogers
Re: Fergy
MartRogers
Fergy
Just about caught up with the last few months work now, this weekend was spent sorting the parcel shelf . Not a nice job, this was the previous section , no idea how it rusted quite this badly .
These two panels came from schofields
i cut the corner down to get it in place and then found out all the ribs are different widths apart and I had cut the wrong side grrr.
Anyway welded the corner back on and out it the other way, after lots of careful measuring and taking it in and out about twenty times it fits pretty well, all of the rib spacing worked out spot on apart from having to cut two inches off one side which left me short on the other so had to make a strip to go down this side. Still needs a bit of tidying and I need to do something on one of the sides where it's rotted a bit higher.
Then made a panel to sort the left side inner arch and welded that in, back is just about down now :)
Time to move into the front !
MartRogers
Fergy
Oh and the rear panel as well.. I was determined to keep the original but offered up a new one to try it..
Didn't look right so set to cutting all the rot off the old one and very carefully stitching the two together
Just got to sort the engine lid now
blink
Re: Fergy
Post by blink »
THis think is amazing!!!
love the look of the van! like the acid wash on the repairs too.
More photos and work please lol
MartRogers
Re: Fergy
Ha that's me up to date so they will come a bit slower now, here is a vid of the peroxide in action, mixed up with some salt and it sets to really quick. You can see it rust in front of your eyes and see the smoke / steam ? Coming off it ! https://vimeo.com/148852964
Max Last
Re: Fergy
Post by Max Last »
Excellent stuff Martin, mind the carpet though, be a shame to ruin it! Fergy will be at the sheikhs in no time!
Bothering the blinkered since 1969.
MartRogers
Fergy
There are one or two slight burns and a few grinder cuts, certainly won't be going back in the front room now ;) hoping for mot in Feb / March so depending how long reg takes the sheikhs may be a possibility
Glenn Yale
Re: Fergy
Post by Glenn Yale »
That's awesome, love how you did the engine lid hinge panel.
