RHD 1954 Samba
ned
Re: RHD 1954 Samba
Post by ned » Wed Jul 26, 2017 7:20 am
Perfection!
Karl_F
Re: RHD 1954 Samba
Post by Karl_F » Wed Jul 26, 2017 7:25 am
Perfect dude! 8-)
Karl
1960 Mango 11 window
Mango build thread
steve j l
Re: RHD 1954 Samba
Post by steve j l » Wed Jul 26, 2017 5:32 pm
Went up Pod on sunday, very disappointing weather... but was super chuffed to have a look round your bus.
Few pics:
Awesome.
"Meanwhile back at the ranch!!"
kilgore
Re: RHD 1954 Samba
Post by kilgore » Wed Jul 26, 2017 6:43 pm
Thanks guys really appreciate all the kind words. Im super stoked. Few more things to get sorted but just so happy it seems to drive ok and so far no major issues :cheers: :cheers: :cheers:
carl12
Re: RHD 1954 Samba
Post by carl12 » Wed Jul 26, 2017 7:21 pm
Looks Absolutely Amazing congrats you must be over the moon.
Look forward to hooking the 2 old girls together
Cheers Carl.
kilgore
Re: RHD 1954 Samba
Post by kilgore » Wed Jul 26, 2017 7:42 pm
Cheers Carl.
That really will be fun mate, whens the planned "finish" date?
carl12
Re: RHD 1954 Samba
Post by carl12 » Wed Jul 26, 2017 8:10 pm
Hopefully not to to long away are let u know.
kilgore
Re: RHD 1954 Samba
Post by kilgore » Tue Aug 01, 2017 2:38 pm
I have a long list of little jobs still to do, most of which are nothing major just fettling but one id been putting off since having a quick go and it being a total pain in the arse is is fitting the deluxe trim insert, my bus came with a large portion of its original trim, complete with 60 plus years of dirt making the red trim look almost black. I wanted as elsewhere on the build to use as much as what is original as possible.
Some of the original insert i have left, you can see the original colour here on the reverse
After a little soak in very hot water the insert went pretty pliable, originally i hadnt warmed it through and it was so dry that when i tried to get it in the trim it would snap and crack.
before
And after
I inserted it leaving gaps at the ends as per what seems to be the norm on other original deluxes,it seems the insert shrinks with heat over time.
The front pieces in, you can see here so dirty they look brown/black
Its a subtle change but im well chuffed that its all in now. I didn't have enough to do all the trim so I have had to fauxtina some :D This involved sanding lightly some repro insert i actually used on my last samba and then rubbing it all over the workshop floor, through oil dirt and grime :D :D :D
Re: RHD 1954 Samba
Post by clymoj » Fri Aug 04, 2017 8:55 am
Nice extra detail.
I love your commitment to using the original parts, makes it a really honest bus
kilgore
Re: RHD 1954 Samba
Post by kilgore » Sun Aug 06, 2017 8:03 pm
Nice extra detail.
Thanks dude :cheers:
This weekend ive been trying to sort out my rear shocks. I wanted the bus to have a tucked rear end making use of the narrower standard barndoor rear end. Unlike a later bus a short axle straight axle box bolts straight in which is exactly what im running here, mine is out of an early type 3. This means however the rear wheels end up much closer to the body and closer still when you factor in the camber added by running at the height im at.
After a chat with the boys I made a template for some shock mounts which i hoped to bolt through the end of the axles and attach the top of the shock to a plate that would sit inside the chassis rail above.
Prototypes mk i
8 mm steel
Basically if my bus was running a long axle set up with would have worked. But due to the proximity of the tyre and inner arch under load where i had planned to run the shock it was impossible. Literally no room.
After some head scratching and lots of cardboard templates prototype Mkii was born
These were drawn up at 10pm on Thursday and by lunch time the following day my good friend Mike had made them for me. Very very useful having a buddy that owns his own fabrication and engineering shop! Thanks so much Mike i owe you plenty of beer!! :cheers: :cheers:
We re tweaked the design of the shock plates too making them sit higher within the scrub line of the wheel and Mike laser cut me some spacers, washers and the plates for inside the chassis.
offering them up for trial fitment
Bolted in and under full load, no clearance issues and appears to work ok
Drove it today and it has made such a massive improvement to ride quality. I need to properly set all the tracking front and rear as its a little lively in the ruts on the motorway but that's a job for an evening this week, happy boy!
Re: RHD 1954 Samba
Post by type21f » Sun Aug 06, 2017 8:12 pm
I do love the "Engineering in Action" approach to problem solving...
Interesting to do some Finite Analysis on your solution to suspension geometry..
Well done..
Check the fabrication regularly!
kilgore
Re: RHD 1954 Samba
Post by kilgore » Sun Aug 06, 2017 8:16 pm
Well done..
If it doesnt exist already, have a go yourself right? I am in no way an engineer and happy to do this on my bus in a non critical area, safety wise. Ive had a few good friends that are more knowledgeable in these things cast their eye over the setup and thus far no body has spotted anything untoward. Id welcome any feedback from others. So far, it has no clearance issues and has stopped the bus from bouncing down the road so im pretty happy
kilgore
Re: RHD 1954 Samba
Post by kilgore » Wed Aug 09, 2017 3:52 pm
Last night re tracked the front and rear! The rears were 16mm toeing out 8O 8O which may explain some of the twitchyness at speed haha!
Adjusted that and re checked the fronts for good measure and its now driving fantastic. The front spax shocks were still too stiff at half adjustment so i have softened them to maximum softness and ride quality is so much better! Finally really happy with how its driving now!
kilgore
Re: RHD 1954 Samba
Post by kilgore » Fri Aug 11, 2017 7:14 pm
Managed to get a few more jobs done last night and today, massive thanks to Snips and especially Rob for his help today, thanks so much boys :cheers: :cheers:
Bus now has the original rear view mirror fitted. Its tatty as hell and the visor is snapped by i love its original to the van. I forgot to take a pic of that but ill post another time.Next job was to get the rear jail bars repaired and fitted.
They are original to the bus and in a pretty bad way, snapped in a few places and pretty kinked and bent.
This photo doesn't quite due them justice they very kinked and very bent :evil:
Ste got busy with the vice and straightened out the kinks whilst i had the slightly awkward job of removing the remains of original samba from each of the mounting clamps.
Id soaked these for days and the screws still will not move.
I ended up using a flappy disk to grind through the screws, remains of bus and the remnants of the original headliner
Straightened, repaired and all the original screws removed :cheers:
I have even managed to save all the original end mounts too from the remains of the original window frames.
Every single part of the jail bar assembly are all original to the bus, little bits like this make me happy! Sad I know :D :D
Next up the real fiddly job of fitting it! Rob has been a total hero and essentially did this for me. The thought of drilling the new headliner was slightly too daunting for me. Thanks dude!! I owe you as always :cheers: :cheers: :cheers:
markp
Re: RHD 1954 Samba
Post by markp » Sat Aug 12, 2017 8:29 am
dude !!!!!
I just done the complete thread
WOW just WOW
well done for saving a amazing bus .... the time and money spent is probably tearfull but
who gives a sh*t hu .... it all your's and its blooooming amazing
hats off she looks so sweet
massive massive respect dude
bet you SMILE every time your drive it ......
Markp
