Nose Cone Bushes
Nose Cone Bushes
Evening all.
Looking to replace the bushes on the nose cone (T2), and the later replacement bush kits that have the rubber seal housing aren't listed as fitting a T2 nose cone, but I'm sure these have fitted in the past?
Can anyone confirm if the later style do or don't fit a Split Bus nose cone?
Later style
http://www.vwheritage.com/vw_spares_Nos ... 159068.htm
Stock style
http://www.vwheritage.com/vw_spares_Nos ... tartRow=16
readyboy61
Re: Nose Cone Bushes
Post by readyboy61 »
Hi Jim,
I had a brand new nose cone fitted on the bus and it has the later style bush and rubber seal
seablue67
Post by seablue67 »
I fitted a later style one but had to add extra shims as the diameter of the later one was smaller so I would be prepared to fettle the later one.
SSVC Van Register
Post by SSVC Van Register »
They changed about 1966 Jim. The seal apparently is not retro-fittable to the earlier nose cone according to the WSM. It coincided with the improved drainage on the internal webbing - thus making the later nose cone a preferred option in my opinion. At least that's the one I have fitted.
Steve.
Thanks.
OxonPhil
Post by OxonPhil »
Jim,
This might be useful.....
http://www.csp-shop.com/cgi-bin/cshop2/ ... ort=0&all=
As there are dimensioned drawings :cheers:
Phil. :D
P.s. I must call you about those clamps :roll:
Well I can confirm that they don't fit properly.
thesickness
Post by thesickness »
vwJim wrote:Well I can confirm that they don't fit properly.
I bought 2 x nose cone bush kits that would apparently fit my 67.. both different but neither fitted. After a long and helpful conversation with Bears I sent my "oddball" nosecone to them and they custom made a bush and seal for less than £20 cant recommend them enough, it was back within days as well. :D
paul_f
Post by paul_f »
Long enterprise did sell a bush for earlier nosecones. But you had to spend quite a lot before they would ship to the UK
Sent from my GT-I9300 using Tapatalk
